Hey guys, If someone could help me with these it'd be most appreciated.
I need the following, and i dont really want to go to some over priced wrecker..
Front right gaurd,
Front right light (series 1)
Radiator support,
Radiator,
Front bonnet.
IF anyone has any of the following, and is willing to ship it to canberra it would be appreciated.
I do realise that the radiator support and bonnet will be hard, so could anyone give me some wreckers that will not charge a fortune for these parts.
Thanks heaps.
Dayne
https://www.sau.com.au/forums/topic/54325-r33-parts/
Sounds good, Would you be able to drop the price to $$450 for both?? + Postage
I'm also buying a front bar, and steering wheel off here aswell, do you think you would be able to combine postage with him? Its probably to complicated though.
Let me know anyway.
Thanks
https://www.sau.com.au/forums/topic/54325-r33-parts/#findComment-1064426
ah really, dont worry then.
Sorry about that, its just im really after a new radiator support, as it'll be to hard, and messed up once its came off, and then been re-welded back on.
thanks anyway!
I have a R33 GTR radiator. Its like new. can supply pics if you are interested. It will slot straight in.
Let me know if you are interested.
[email protected]
https://www.sau.com.au/forums/topic/54325-r33-parts/#findComment-1066228
[email protected]
Man, im keen on the radiator! I've sent you an email & added you on msn, how much are you after??
https://www.sau.com.au/forums/topic/54325-r33-parts/#findComment-1070407
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
