Guest Mashrock Posted March 9, 2005 Share Posted March 9, 2005 its 6 point i beleive. but minimum requirments for improved production racing. Link to comment https://www.sau.com.au/forums/topic/54507-ae86-discussion/page/7/#findComment-1243183 Share on other sites More sharing options...
silver gts-t Posted March 9, 2005 Share Posted March 9, 2005 you could use that car as a suicide bomb, and then re-use it Link to comment https://www.sau.com.au/forums/topic/54507-ae86-discussion/page/7/#findComment-1243394 Share on other sites More sharing options...
Guest Mashrock Posted March 9, 2005 Share Posted March 9, 2005 we plan on taking on trees.. Link to comment https://www.sau.com.au/forums/topic/54507-ae86-discussion/page/7/#findComment-1243620 Share on other sites More sharing options...
Craved Posted March 11, 2005 Author Share Posted March 11, 2005 y0 craved, my engine mount for the CA18 seems to be showin some stress due to engine twist. My fault I guess for doin some ghetto welds How much is the full engine and gearbox mount kit from where you got it? ok, the brother of the owner and i created a new one for the passenger side, the easiest thing i could suggest you could do is to create a JIG from your existing one including templates for the end plates, hole locations etc this would allow you to get these done extremely cheaply. and be easier than us designing them for you since we are using engine mounts from a jap spec corrolla (dont ask - they were already on it) take the JIG and the existing ones to an engineer, this would allow them to ceate them without having to work it all out, hence they just cut the steel and welding it for you.. would be stronger and the they wouldn't have to spend much time creating them. which will make it cheaper. take most of the labour out of the equation. the gearbox mount was simply a standard gearbox mount with the centre modified and a reinforcement plate welded to it to align with the mounting holes on the ca18 box ... not too much work involved, although the gearbox and everything is back in the car so i cant get photos for you. we have welded the new rear quater skirts and tailgate back on to remove the rust, the modified lower control arms have been lengthened and reinforced .. they are bolted back in , just waiting on the new custom sway bars to arrive. adjustable strut tops are in place.. just have to find a shock setup to allow a high level of lowering while maintaining a wide range of motion before bottoming out. can you confirm if the front suspension of an MR2 is usable on these? oh and use a higher grade of steel on the engine mounts.. what rubbers are you using? try and find something that has a harder compound.. as ours are a bit soft to cope with the ca18's power/torque movements. Link to comment https://www.sau.com.au/forums/topic/54507-ae86-discussion/page/7/#findComment-1246104 Share on other sites More sharing options...
funkymonkey Posted March 12, 2005 Share Posted March 12, 2005 aw crap... I guess I have to take the engine out at some point or other.... I'll take em out and take em to a proper fabrication shop. Link to comment https://www.sau.com.au/forums/topic/54507-ae86-discussion/page/7/#findComment-1247328 Share on other sites More sharing options...
Craved Posted August 17, 2005 Author Share Posted August 17, 2005 hows your Project going Shan ?? considering buying one myself as a daily driver... the one we have been working on has just been prepped for respray.... welll its been primed and waiting for the sanding back... then spray.. should be going candy red for it, i just wish the owner would get a body kit for it before it gets sprayed. you know anywhere to gets kits for em? Link to comment https://www.sau.com.au/forums/topic/54507-ae86-discussion/page/7/#findComment-1527914 Share on other sites More sharing options...
funkymonkey Posted August 21, 2005 Share Posted August 21, 2005 not as fast as I'd hoped unfortunately... the engine will be put in sometime this month. I've been fixing up the little niggles and stuff on the R32, coz I'm looking at selling it soon, so the AE86 has sat in the back of the workshop for the last couple of months gathering dust. Me n inark are dabbling in some fiberglassing so we can make our own custom kits, but at this rate it might take us over a year Link to comment https://www.sau.com.au/forums/topic/54507-ae86-discussion/page/7/#findComment-1536249 Share on other sites More sharing options...
Craved Posted August 22, 2005 Author Share Posted August 22, 2005 which engine did you go for again Shan...? Link to comment https://www.sau.com.au/forums/topic/54507-ae86-discussion/page/7/#findComment-1538920 Share on other sites More sharing options...
funkymonkey Posted August 23, 2005 Share Posted August 23, 2005 CA18DET, with CA18 gearbox, T18 diff and TRD 2 way LSD. Ended up deciding to try and adapt the S13 engine crossmember to fit onto the AE86 chassis, and at the same time mounting the S13 power steering and steering column in rather than using the less than inspirational toyota one. Link to comment https://www.sau.com.au/forums/topic/54507-ae86-discussion/page/7/#findComment-1539566 Share on other sites More sharing options...
Craved Posted August 23, 2005 Author Share Posted August 23, 2005 sounds like a little extra work with the S13 crossmember... but atleast then you would be able to use the STD. engine mounts. whats mods you have to do to use the steering column through the AE's firewall?? Link to comment https://www.sau.com.au/forums/topic/54507-ae86-discussion/page/7/#findComment-1541168 Share on other sites More sharing options...
funkymonkey Posted August 24, 2005 Share Posted August 24, 2005 dunno, will let you know when we get around to it still trying to fit the cross member and make the suspension fit. Worked out easier tho, all I had to get was an S13 cradle without engine, and got all the parts. Also means I'll get to use standard S13 bolt on suspension parts and have a smaller steering wheel lock.... and power steering Link to comment https://www.sau.com.au/forums/topic/54507-ae86-discussion/page/7/#findComment-1543524 Share on other sites More sharing options...
Craved Posted August 26, 2005 Author Share Posted August 26, 2005 what do you need power steering for looking for a daily driver now .. cant decide on something to gte for $6K ... sooo many options Link to comment https://www.sau.com.au/forums/topic/54507-ae86-discussion/page/7/#findComment-1547927 Share on other sites More sharing options...
funkymonkey Posted August 27, 2005 Share Posted August 27, 2005 going in very soon! but then... there's this to attend to... Link to comment https://www.sau.com.au/forums/topic/54507-ae86-discussion/page/7/#findComment-1549044 Share on other sites More sharing options...
POOMBAH Posted August 28, 2005 Share Posted August 28, 2005 Any1 watch the drifts today on SBS? A yellow hachiroku won Link to comment https://www.sau.com.au/forums/topic/54507-ae86-discussion/page/7/#findComment-1549259 Share on other sites More sharing options...
Craved Posted August 30, 2005 Author Share Posted August 30, 2005 when was the drifting on? never get know when its televised is that an R32 getting the wide body? Link to comment https://www.sau.com.au/forums/topic/54507-ae86-discussion/page/7/#findComment-1554666 Share on other sites More sharing options...
funkymonkey Posted September 2, 2005 Share Posted September 2, 2005 drifting was on Foxtel on inside speed. Yellow 86 would be crab methinks. and yessir... that would be my 9 piece BN Sports Widebody kit being test fitted. 50mm on either side. The wheels on the car are stock silvia ones. Link to comment https://www.sau.com.au/forums/topic/54507-ae86-discussion/page/7/#findComment-1560651 Share on other sites More sharing options...
Rezz Posted September 2, 2005 Share Posted September 2, 2005 and yessir... that would be my 9 piece BN Sports Widebody kit being test fitted. <{POST_SNAPBACK}> Is it gonna take you another 2 years to mount the thing Shan? Link to comment https://www.sau.com.au/forums/topic/54507-ae86-discussion/page/7/#findComment-1560696 Share on other sites More sharing options...
Mandingo Posted September 2, 2005 Share Posted September 2, 2005 Are you sure thats an R32 or am I crazy? it looks like an S13? Link to comment https://www.sau.com.au/forums/topic/54507-ae86-discussion/page/7/#findComment-1560834 Share on other sites More sharing options...
funkymonkey Posted September 3, 2005 Share Posted September 3, 2005 siiiif I'd waste my time on an S13 (the AE86's gettin most of the S13 parts anyways). Besides, with all the kids running around in widebody S13's S14's and S15's I need something different. Its for my R32, and no it'll be done sooner than 2 years, maybe next year or something. lol I cbf. Here's the finished product on a car in JP. Link to comment https://www.sau.com.au/forums/topic/54507-ae86-discussion/page/7/#findComment-1561025 Share on other sites More sharing options...
Craved Posted September 12, 2005 Author Share Posted September 12, 2005 that looks Hawt ... could you tell us what you paid for the kit? or is it an original kit thats through to roof? Link to comment https://www.sau.com.au/forums/topic/54507-ae86-discussion/page/7/#findComment-1580046 Share on other sites More sharing options...
