kit is an original BN Sports... cost... well retails for 273,000 Yen, which is $3300 by todays exchange rate, plus shipping n all that.
For the AE86... bought 4L of canary yellow acryllic, 4L of thinners and 4L of prepwash n 4L of clear today for $320... time to paint up the engine bay and put all the parts in. Bought a S13 cradle (control arms, suspension, steering rack etc) for $500 as well. costs are starting to add up now :)
  • Replies 154
they always do.....
um up to about $12K on the line in the last 6 months :) ooh well should go hard.
thats pretty damn cheap for paint.. but its only acryllic .. why not go for 2 pak paint? but then again your already on the costs.
our AE is almost ready for painting.. been undercoated and is still halfway through the rub back... still reckon at least a month til its done....
im in the search at the moment for an ae86, with fuel pricers rising the skyline becomes more and more a weekend only car.
i've always been a fan of the ae86, my mate has own 3; aus levin with 4ac then aus levin with 4age swap and now he has a jap ae85 tureno coupe.
i just want to find myself a nice clean ae86 i really like the tureno soo its going to be soo hard to find one cheap, i might just end up getting aus spec levin and going a 20v swap and put some quads on it
thats still a popular mod in Japan... just get the black top 20v as it has more power std than the silver top.
That's actually a mate's car that's being race-prepped (sitting next to my AE86), which I tried the kit on as it already had all the panels off. Its got a full cage in it (only half of it in while we redo the wiring in the car).
I can get em from Japan, but as I said, they're not cheap ;)
my mates car. i have more recent photos of it but i am in the us on my laptop so this is all i have
nice...
where abouts did he get the rear wing??? and how much?
and how did it get attached ... we wanna put it on the sprinter.. but need to get one and figure out the attachment before we continue the prepping.
got some info on the weekend....
found a sprinter coming into the country in a couple of weeks..
4AGE..20V with HKS cams
coilovers
mech LSD
BRIDE buckets...
have to have a look at it once she comes in.. but im pretty sure i'll get it!
Avi, his website's http://www.jap.com.au tell him Shan from j-spec sent ya and he might cut you a deal... or not... his username's a_v_i on most forums (SAU and NS included).
http://www.jap.com.au/ae86.html
oh and I have a "JDM tyte" AE86 front grille (the clear one with spaces for foggies... think they're called letterbox style or something) for sale too... and a whole heap of interior bits and pieces and a set of trueno headlights with motor assemblies.
how long you been at j-spec for shan???
always looking at that site for nice bargain :D
that convert silvia looked good the other day...
my mate just got import approval for his s6 rx7 race car he got through you guys ... cant wait til it comes into the country :P
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
