theres the kit for the GTS 4door, always wanted one of those if i was keeping the r31. try powerplay (i dont know any contact details) as they can get kits from japan for the r31..
saw a drift style bonnett from japan that was $1000 that i would have killed for...by the way do you have a 2 or 4door r31?
HOW & WHERE do you get these bits.
The links often don't work and I have been trying to get a Passage GT rear wing for my R30 for months.
I get told all these stories about everyone takes them off, but I can't find one for sale.
An R31 GTS-X rear spoiler would be cool as well or in lieu.
The side skirts would also fit the R30's.
I've been chasing a Passage rear spoiler for almost 2 years now.
I even drove all the way to Bendigo because i was assured that the seller had the one i was after, and when i got there it turned out to be a gts-x wing.
Talk about pissed off.
I got on to one in Melbourne about 12 months ago, as per attachment. It turned out the person selling was a kid of 16 and we agreed on a deal of $220.00 delivered to me in Sydney, but he procrastinated for about 8 weeks and eventually said he had someone in Melbourne to buy it for the full amount $220.00 and he didn't have to wear the postage.
And then I was pissed off, and have been looking ever since again.
I know how you feel.
if you want something like that then i have one in the boot of the r30 i'll post up a pic on mon as its still in the boot and the cars at the shop... its black, a hardish rubber and has some writing on the side, forgot what it says...
hey sorry net has been down for a while this thread got pretty messed up since i left :band: hey i mainly after realy nice bumper and sideskirts something to make the car look realy MEAN :) im not sure but i found this kit for a maxima how hard would it be to fit that to a R31? or is it just out of shape or simply to small/big ?
http://www.customautotrim.com/bodykits/kam...nari/maxima.htm
That place is in USA, the freight would be a killer. Probably better trying to get from R31 House in Japan.
Go have a look at Fibremaster at Arndell Park, they have all the old GS Motorbodies moulds. www.fibremaster.com.au
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
