Hi,
Picked up a RB20 front cut on the weekend.... started it up in my garage las nite... the damn thing is running so rich and idling like a dog... whereas at the place i picked it up from it was smooth as! The only thing that I can think is different is the fuel pump I have, it's a denso around the 255lt/hr mark. The dude told me that the injectors would struggle with it and I would need to get a new fuel reg. I had this pump on my SR20 with no mods the anything on the fuel side of things and it ran fine.... am I barking up the wrong tree by thinking it's the fuel pump?
Thanks,
Ed.
https://www.sau.com.au/forums/topic/55051-fuel-pump-on-rb20det/
I wouldn't think it was the pump, as the standard regulator seems to cope fine with the bigger Bosch pumps etc
I'd be checking for a vacumm leak, or a intercooler hose not connected - I take it you are running it out of the car? If so this would most likely be the problem, as it sounds like what happens when you run the car with a loose intercooler hose etc
Just my thoughts :(
Chris
yeah there is one section of intake (hot side of the cooler just after the turbs) hose without any hose clamps on it, but i didnt think this would affect the idle... when it reaches +ve it starts to affect things.... there are so many damn vaccume lines without clamps on them too :( I think it's going to take me a while to find it if it's a leak...
the motor is currently sitting in a front cut.... one other thing i was thinking could be affecting it... the only exhaust on it is a 3" dump... no cat (the car is chopped at the a pillar).. and if the 32 is the same as my s13, there would be a O2 sensor on the cat correct?
afm is plugged in... will check all the hoses i can tonite.. checked all the i/c plumbing and it's all on correctly (except the one with no clamps....) will check the rest 2nite....
any other ideas?
no clamps could quite easily mean a leak even at idle
if you don't have any clamps (which you can get from bunnings by the way) then use cable-ties just to test it out. you might be surprised that although a hose seems to be securely on, even without a clamp, it probably will still be leaking.
cheers,
Waz.
My money is on the intercooler pipe - mine poped off once on the outlet of the intercooler, and it wouldn't idle and blew balck smoke (fuel)
There are many vacuum lines as you know doubt can see, all can effect idle quality
Chris
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
