i'd like to know how he has no MORAL obligation to hand the sample over.. wtf????   hes a supreme court judge!
he would hand it over if he was under at the time wouldn't he!! implies his guilt in my eyes!
absolutely.....what an amazing idea....no credability for Mr Judge.
Imagine he was the one ruling on a drink driving case?
https://www.sau.com.au/forums/topic/55068-pigs-arse/#findComment-1075063
I use to study legal studies i school and I learned
"The law is applied equally to all"
Now I've added my own extension to that,
"unless your in a position of power".
I would like to hear what he has to say to the next drink driver he comes across in court.
https://www.sau.com.au/forums/topic/55068-pigs-arse/#findComment-1075669
He does have a moral obligation, arguably. Just not a legal obligation. You wouldn't either in the same situation (have a legal obligation, that is).
Personally I don't think its all that amazing the sample got lost; these things do happen. I'm not sure anyone in the police service would loose it intentionally: why would they? It just makes them look bad. Moreover, it should be rather easy to track down which officer/etc was responsible for picking up the sample...
LW.
https://www.sau.com.au/forums/topic/55068-pigs-arse/#findComment-1075675
I have some contacts in this area and he was definitely sozzled.  Word is that he has been that way for about a year and a half now...
As usual Adam is on the money:
http://www.smh.com.au/news/National/Judge-...0384433637.html
Not only did he have one copy of the vial but he also had the second. And knew everyone was looking for it.
Now resigned and in detox
https://www.sau.com.au/forums/topic/55068-pigs-arse/#findComment-1087180
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
