Just looking for advice.
I have installed a profec B (series 1) on my Rb25DET in an R33 4 door with auto and it seems to work OK, but the boost is comming on later than when I had a bleed valve.
It holds boost well, and my dyno graph is smooth and well shaped, (and produces a few more kw than the bleed valve and has a much better shape) but it comes in much later. I have set the ballace to 100% sharp.
Has anyone else come across this or have ideas on how to solve the problem.
PS. Vacume pump is located on the strut tower next to the original boost solioid, and the vacume line is tapped off of the rising rate regulator line (front of plenum)and fed back through the fire wall behind the right wheel.
https://www.sau.com.au/forums/topic/55229-profec-b-boost-problems/
Playing with the sharpness controls can alter when boost comes on.
I wouldn't recommend 100% - After countless adjustment on the road I found that around 1/4 produced some of the best results for my old r33. Every car would vary though. Start at 50% and work up or down from there.
You really need to see when boost rises nicely and best holds at xx psi when you are on full tap. Alternatively if it comes on too quickly it will simply spike, and drop off at high RPM. I could see it exhibiting this on the boost gauge.
Once you find the perfect medium its a great EBC, but I think a lot don't bother playing with this control properly.. which is very important to get the best adjust.
Really need to set it on the dyno - as its pretty dangerous to set on the street and you can only really notice these things under flatout acceleration. I would also note that quite a few places I took it to had absolutely no idea what it was even for :-s
But I have sharpnes set to 100% and boost still comes on LATER than my old bleed valve.
It holds boost perfectly, and has been set up on a dyno, but looking at my old graph and new graph it shows the power is down (through most of the rev range) as boost comes on later.
wreckedhead I am guessing you bave the seec II controler, mine only has a low and high boost button without a readout. Have you been to http://www.greddy.com/ for help. I think there is a pdf that mentions this sort of thing. (you can change the dip switch combination to make an adjustment)
there are 3 vacum lines
2 are from the actuator to the under bonnet unit (???) to the inlet pipe, but the third taps off of the inlet plenum and runs direct to the control unit inside the car (- this is the line I have tapped off of the fuel regulator).
I have used the shortest length lines possible between the inlet pipe and actuator (about 15cm each)
I had no probs with mine.As Predator said start with the balanceat 50% and work from there.I found that about 75% worked best with mine.Sounds like you it all connected up right.What I did with the hose that goes to controller in the cabin was tee into the charcoal canister,I did'nt really what to get it from the fuel reg.
    • Mainly being afraid of breaking something on something i've poured so much money into haha
    • Hey   ive gone for a terminated harness on my build so selling brand new unused and unopened piggy back harness  https://www.haltech.com/product/ht-141357-elite-2000-2500-nissan-skyline-r32-33-r34-gt-r/ Located Bathurst NSW   price $600 + postage
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
