  • Replies 85
i hope so! i think it all bolts up.  Kit comes with its own dump and all the lines. I think the one thing ill need is a new intake pipe as the compressor inlet mouth looks big, but im fairly sure its a blot on kit.
can someone with ~280rwkw comment on drivability? are these cars still fast at speeds below 100 or is it just wheelspin city?
While i love power, it makes you slower if you cant get it down!
Its very rare that on normal roads you open the car out to 7000rpm in every gear.
With the price of petrol these days i much prefer driving my gfriends car around day to day
300kw's is my power goal eventually also. Sounds like an awesome whack of power.,. As for bolt on turbo i have witnessed some TD06's on rb25's and they go well. IO have been in a r33 which had a HKS 3037s and microtech and cams etc and it made 350hp at wheels on 1 bar. Was rather quick but very wheelspiny. guess its personal choice on turbos.
Would it be a better idea if i was to say put garret gt2535 on my car rb25det,with usual mods,with a different size ar.Here is a reply that i got from horsepower in a box.com
I can do the GT2535 in the T3 flange internal gated for $1750, but not the
GT2530.
We also do a 500hp core unit with a .70 comp cover for the RB25 as a bolt on
Internal gate for $2150.
Regards
Is this option a good one for this turbo and motor with stock internals looking at running cams?What sort of spooling rpm time could i expect it to come onto boost from the upgraded version?
For me i feel 250RWKW is perfect for the street/circuit. Only problem is finding a turbo that will hit full boost at a low rpm(say 3500-4000) and make that amount of power as well, Because we all know bigger turbos=big power=lots of lag. I think to achieve 250RWKW with a little lag(compared with stock) you'd need cams, ported head and port matched inlet and exhaust ports. All these help reduce the lag and up the power too. In my opinion ball bearing and being water and oil cooled is a must for the longterm, plus the ball bearing aspect helps in cutting lag.
GT2530.
Regards
:D
Only probelm with these type of turbos is that you will always have boost control problems and sureg problems when trying to pump out alot of hp from a internal gated turbo!!
is the reason being that in order to control boost pressure on a big turbo, an internal gate wont allow enough gas out to make the boost change needed?
From Grepins Thread, posted by SK regarding the GT2835proS
Hi grepin, I like it, it has....
270 rwkw at 7,300 rpm
277 rwkw at 6,300 rpm
246 rwkw at 5,300 rpm
210 rwkw at 4,300 rpm
That's an average of 251 rwkw over the useable rpm allowing for gearchanges. There are plenty of cars with over 300 rwkw that don't average 251 rwkw.
I think it would be a nice car to drive, fast and progressive.
BTW guys, notice this dyno run was not in Shoot Out Mode, so no ambient air temperature compensation. If it was a 31 degree day, then on a 19 degree day it's gunna make a smidge over 300 rwkw with an average around 270 rwkw.
Wanna guess what the A/F ratios would be then? In my opinion Mick has done a good job, looks to be both safe and powerful, you don't see that everyday.
As I said at the start, I like it!
trust33, bear in mind that Garret GT25 series are not the same as HKS GT25 series. for example to duplicate the ~250rwkw from a HKS GT2535 int gate youd need a Garret GT3040 int gate.
All because of the different compressor and turbine blade designs?
I have read that on sdu forums by mariogtr that whatever turbo i use the hks will allways flow closer to its full potential than a garret equivilent.He says somewere in the vicinity of 20hp is what you should take off of a garret turbos rating and it would give a better indication of what this turbo will pull.
Also being that all of these turbos are rated at stock boost 10psi or so.So there will be room for more power.
I say,now being that a stock rb25det turbo is rated at 250ps and has smaller .ar housings and includes ceramic bladed turbine,non ball bearing turbo and being able to see the power they can produce when pushed,that a garret or hks turbo with a better ps output to start will surely make arround 380-400 ps of what i am after.The only difference being that HKS will make it there easier.
If going an underrated turbo what are my chances of being able to elliminate/minimise lag and be able to come onto boost by 3500-3800 and still be able to make the desired 380-400hp/ps output int gate and run minimal boost?
Hks would be good but to be able to afford a brand new one i would have to buy from os.Have you seen hks-T au prices!meh..
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
