Hi guys... your all wondering where the members only forum is i know...
Its there... but there is a forum-wide problem at the moment that wont save permissions.
You guys are added, but the forum is deleting you guys off and not saving the changes.
So we havent forgotten about you all. Its a bug of some sorta
Prank is aware of the problem and will address it in due course.
cheers - ash
https://www.sau.com.au/forums/topic/55295-attn-sau-vic-members/
i still havent gotten my membership yet.....can i sign up next meet or somthing?
yes, thats no problem at all.
Jetdat... yer... soemthing due to an upgrade of some sort.
Its not just us either. WA guys have ben suffering for weeks :)
so r31nismoid will you send info of how to access the area when i up and ready and how does it work will we have new passwords or will it just be under our logins
cant wait to have own area
you will be able to access it as if it were new subsections of the VIC forum, so no new passwords to remember and no need to login again etc.
Those who don't have membership won't be able to see it. Its there right now, but because the permissions aren't being saved, there's no way you guys can see it. ATM only the mods can see it. Once we fix up the permissions those that have paid membership should be able to see 4 new sub sections underneath where the current events subsection is listed:
Members Only Events Discussion
General Club Discussion
Membership Questions
Special Deals and Promos
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
