Is it just me, or is the search system in vB a little screwed. How do I go about searching for threads or posts that only include A and B, not just A or B?
Once upon a time using the expression "a AND b" (minus the quotation marks) would have worked, but currently vB seems to just see those as seperate keywords, as if I had searched for "a b".
To give you some context, lets say I want to search for threads or posts that only contain "HKS" and "exhaust". If I put in "hks AND exhaust" as the query, it gives me any thread or post that contains either HKS or exhaust (or both), but not just threads/posts that contain HKS and exhaust.
Anyone able to help...? :)
LW.
https://www.sau.com.au/forums/topic/55328-search-queries/
Hi Christian,
I tried the '+' operator just before I bumped the thread, and that doesn't do the trick either: they are still treated as seperate keywords (ie. as if it was an 'OR' situation)...?
Weird. Makes search practically useless IMHO :)
LW.
https://www.sau.com.au/forums/topic/55328-search-queries/#findComment-1088261
umm yeah it seems to be borken, + used to work fine.
please please please please please please please please fix prankster....I like picking on people for not searching and I can't be as mean when search isnt working properly :rant:
https://www.sau.com.au/forums/topic/55328-search-queries/#findComment-1088627
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
