  • Replies 110
Mate has taken out the mesh on both sides of his Z32 sensor & actually dynoed it! And guess what it made more power with the mesh removed, plus he actually flow bench tested with & without the mesh & picked up a bit from removing it! he actually went a step further & got some epoxy ribbon & made the plastic section where the wire is inside smoother & also flowbenched this which again improved flow & hp on the dyno! This car has really good A/F ratios now without a modified ecu other than the speed limit removed & made approx 209rwkw ( not on shootout mode either !)& ran 12.592@182kph! This is not BS you can check the time on http://www.drivelinechatter.com/dragladder_list.asp to verify! obviously it has other mods but mods to sensor seemed to help his a/f ratios
sends mixed messages to the ecu
i doubt removing both of the grills would send mixed messages. there is only one input - the AFM - to tell how much air enters the engine. this is measured after the first grill - and only measures how much air hits it to cool the wire
Originally posted by rev210
from the look of the mesh there may be as much as 3-4kw@motor in the top end by removing both. More if you have a higher output engine than stock (ie: big turbo)
What is all the talk about *both* or *two* pieces of mesh?
Mine only had *one* on the airbox side, which is gone now...
Maybe its just one of the differences in the models ~ 33 > 34?
the mesh is there to stop knuckle heads from poking screwdrivers into the hot wire. It is a restriction and you will increase airflow/hp by removing it.
It is not designed to 'smooth airflow' it is just cheap-ass(uneven and poorly constructed) mesh.
Do yourself a favour after checking your head for knuckles.
That is a classic ~ very funny!
Hope I'm not interupting, but I was told 2day by BD4's that the k&n, unifilters and others along the same line use oil in the sponge and that it could damage the engine if the oil leaks.....they recommeded HKS air filters ....as it used steel mesh rather than sponging with oil.
Is this true?
Apologies for goin off the topic.
I would imagine that the oil from these "filters" is no worse [or better] than the crankcase return which goes through the turbo anyway...
unless of course you have an oil separator / catch tank.
hotino and others, although the link below has already posted in a different thread. It is a very interesting short read about some brands of air filters, their effectiveness, and how their manufacturer can promote misleading information.
http://www.mkiv.com/techarticles/filters_t...st/2/index.html
edit: It might shed some light on some misconceptions going around as to which type of filter is best for your car and your AFM.
Guest TTZ32
Definitely a worthwhile mod, from memory(been a while since I did it) removing the screens from the AFM increased the flow around 120CFM @ 10" water, it improved the flow by around 25%. I did it to improve spoolup more than anything, but it gave a gain in HP also.
It's all the little things that add up to a large gain, and the cheaper the better.
I don't think there is any advantage to an oil filter.
Hmm, well i cleaned my AFM.. made sweet f.a. difference so either it was clean or it didn't matter.
Found out that both screens on mine had already been removed... there was a tiny bit of dust lining in there, not that great, but probably just proves how crap most pod filters are at actually filtering air.
Guest TTZ32
The hot-wire element is actually self cleaning. After the engine is switched off, the ECU heats the element red hot for a second or so to burn off any crap.
But they still seem to get a build up of snot on them over time.
For interests sake, I've been cleaning mine occasionally over the last 4 years, using carb cleaner, no particular brand, and haven't had any problems. The first time i cleaned it, I used carb cleaner and a toothbrush to scrub it. The element is very robust and unlikely to be damaged easily.
I can't recall EVER hearing of a Nissan hot-wire falling apart.
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
