Slotted Brake rotors - can anyone hook me up with a good deal?
Hi guys,
need to get hold of some front brake rotors, DBA 4000 series, part number 4963, to suit R33 GTS25T front rotor, left and right
Does anyone know/or can get hold of these for a reasonable price?
Thanks in advance,
Chris
Group buy would be good, but I need mine for 22nd of November, as I have a few days off to get my car up to scratch for a upcoming track day
Joel, was that price for slotted rotors? Autospeed want around $270 ea
Might even go with machined up stock rotors, being a fiar bit bigger than the R32 rotors, they should still work better even if they are not slotted
Chris
Autospeed are rip offs.. :P
Discpads want $184 each.
What pads have you been running Chris?
I ran Bendix Ultimates (~$100 a set) on new rotors quite some time ago, through the hills I couldn't get them to fade.
The pads only last 20,000km's though :)
Yeah, I thought Autospeed was a bit pricey, although a few places over here have qouted me $350++
What rotors did Autobarn price you on Joel? as that price is very good!
Pad wise I ran Ultimates, but found them too dusty, so when I got the slotted rotors I ahve now (standard R32 size) I got a set of Racebrake RB74 pads, which are by far the best brake pad I have ever used, so I will be using these again. Also been on for 25,000kms, so they last a while, and living in the hills, the brakes are used quite a bit
32/33 pads are the same thing aren't they? I have about 40% left on my current ones, and was hoping to use them
Guest two.06l
Chris
We are in the market for a full set on our r32 GTR, need them by the end of the month. Group buy anyone?
I'd be keen if you could get a decent price for DBA 4000 series - part no. 4963 - 296mm slotted rotor to for R33 GTS25T, left and right :P would need them by the 22nd or 23rd of November though.........
Here's the prices I just got from Autobarn.
DBA Slotted Front - $229
DBA Slotted Rear - $229
DBA 4000 Slotted Front - $240
DBA 4000 Slotted Rear - $240
EBC Dimple & Slot Front - $289
I swear origionally I was priced in the $180 range. It was an older bloke that quoted me, he knows of me so maybe thats why I got a better price origonally?!?
www.discpads.com.au appear to still be the cheapest.
He did say however that they possibly can do a little better on the price. :P
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
