Not sure if they will fit or not, and not sure if he still has them or not, but I sold a set of 255/40/17's to one of the guys that works with Ed. Have a talk to him and see if hes still got them, and if they will fit :cheers:
ok i'll call him in the morning, and see, but if he had them i assume he would have mentioned it by now, then again its very likely it didnt occur to him, as it didnt occur to me untill yesterday.
i have untill tuesday or my rego will be cancelled (fu**ing vultures) it would be better if i could find a workshop who werent sucj tight asses about a tiny bit of low tread on one edge of one tyre, oh well.
hey mate, well Jayce was kind enough to offer to lend me a pair, but i ended up getting a free easily legal pair (to keep) from dusky007 (alot of you will know him from garagetitan) so they are on and im having it checked tommoz. but i doubt i will get a mechanic that wont be tight and stiff me for something simple. and if they exist i dont know where they are lol.
a hell of a lot of pain on my part would have been spared if the prick hadnt ticked the "full inspection required" box.
had it inspected today, rear wheel was knocked back for being to low on tread, which i couldnt beleive!?! so im starting work at 11am, and i have to find a legal tyre, and have it on and checked then take the car into a shopfront and have it cleared all before i start work, or my rego will be cancelled.
they could let it pass, to put it simply, but they wont.
i have 3 formals to do, and come hell or high water i'll do them, i made a commitment and i'll uphold my word, there is always a way to get things done, and when it comes to the crunch im sure i'll find a way to get it done, im just rapidly running out of time.
just called dickson, with the hope i may be granted an extension, apparently i have another 2weeks to have the defect cleared......WTF?!?!?! i was told that i would receive a letter in a few days saying i had a further 2weeks to have it cleared, i wouldnt be fined any extra and there would be no penalties, so thats news to me, but good news in this case. :@)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
