yes there has been a lot of speculation about power fcs for rb20s...
and yes certain prices are listed on certain websites...
but im yet to here from anyone who has bought one of these that it was actually as easy as everyone makes out. i know how much i paid, and i know how long i waited.
they are the only known facts on this issue. i dont care if im proven wrong, but i dont want to hear about what people have heard, or think they can do, or are gonna do in a few months, or whatever.
Well i'll just oreder mine from the imports part people i used to work for then
Discount for ex employee's :)
If its that hard i'll make it easy
hahahaha now thats just ****ing owned
AP engiineering... 1600 with H/C delivered brand spanker... thats with a middleman - hate to see what the REAL price is
- adz
I mean beaacue i used to work at an import place i still get cheap things but i mean i wouldn't know off the top of my head i havn't worked there for 3-4 months now......
Not being disrespectful just commenting..........
Joel, what web site you talkin? Greenline? Pm me I'm about to order the whole kit AP FC/HC and FC EBC, I got a quote for just over what this guy is askin for just the FC!
Aybee,
GOt mine on friday, waited 3-4 weeks due to a hold up with my intercooler that i ordered aswell. Cost me 1250. So for all out there wondering, there u go.
George
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
