man.. ni if u rape that cefiro anymore you're going to get thrown in jail!!
May as well sell that nice motor it has as well..
I'll give you $1200 for the gearbox.. pickup December :P
lmao well if no one buys it im going to break it down into parts and chuck my mates RB20 in it and keep it lol.
-Engine 7k
-Geabox 1200
-Kit 1500
-Wheels 2k
-FMIC 800
-PODs 500
-Clutch 1200
-LSD 1500
and all the other bits... would probably be able to get more money than if i sold it as a whole :D
  • Replies 54
the kit being genuine = bah who cares copy or genuine :P
As for raping it more - what you've done is already disgusting enough. ... sorry but it is - someone with more money should have bought it O_o
(or you should have won a scratchie or something to keep it in one peice).
$900 = i'm out that's too rich for me.
people who want something to fit properly care if its a genuine or copy.
as for someone with money should hav bought it... i actually do take offence to that and i dont think its any of ur business. I had the money and then some to put this on the road... as stated over and over a-***in-gain something popped up in the middle of importing which set me right back.
lol I remember ringing you to tell you the car was available...
"narkeh... you sure you want this car?"
"yes farken"
"have you got all the money for it? I mean it needs work"
"yes farken"
"ok the car's yours then"
"w00t" *inark dance*
6months later...
well true, its really his money, he can do with the car what he likes! much as it was a nice car (well it looked nice) all as one.
But I am actually serious about the gearbox, as I need it for what I am doing... have the cash right here and will be driving down to melb at xmas for about 2 weeks. Maybe even the clutch (is it a twin plate?). Can't seem to find any decent rb25 gearboxes up here at the moment.
Anyhow, keep it in mind.
dude i dont even know if it really is a RB25DET box... ive seen it... from underneath... but its not like i know what an RB20 and RB25 box has in difference.
do u know if it has like a part number stamped on it??
yeah the clutch is an OS Giken Twin Plate... well... from what ive been told... sounds reliable judging by the huge OS GIKEN sticker that was on the car :P
Not to pick but if it's an exact copy in theory it should fit the same, but I'll pay the point it can be considered inherently better cos it's original.
Sorry if you're offended - I can't help that other than to say I didn't mean to offend you.
having had a couple of "cheap" copied front bars i can speak from experience when i say that copies generally tend to not slide on as easy as the real thing and generally take some fiddling around to get on and look decent up close.
But yes... genuine is genuine and will always be worth more than a nock off... especially when if u want to make copies that do fit reasonably well... u use a genuine item.
And the funny thing is - my kit is like that and it don't fit too well haha, nor is it made that well.
Yup. So lend it to us Sydney lads for $200 or so and we'll give it back to you after a couple of weeks ;) (no seriously)
hehe :D
nah not yet... which is good and bad... bad because its delayed some plans i have... good because i know get to enter banzai battle crazy #1!! ;)
dont spose ur makin ur way over are ya? i know a few of the WA peeps are coming over.
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
