  • Replies 1.2k
not too many people turned up last tuesday but shmeh it was still good, im looking forward to seeing kates new car this tuesday :):) BTW update on games if anyone is interested in getting midnight club 3 i got it for xbox and ps2 selling for $40 but price is negotiable :)
hmmmmm ok then well ive got the midnight club 3's but i also got a copy of GT4 going for $40 and Forza for Xbox going for $40 there both brand new as are the midnight club 3's. i also have star wars episode III the game for Xbox and lego star warsfor xbox brand new going for $30 each so if anyone is interested ring me or txt me cause i cant check SAU often now cause laptop is down :) (dont worry GM_GTR ive still gotyour copy for you :()
back on topic who is going to trivia tonight?
yeh ill take you up on that hehe. wat time are you looking at coming home cuz my dad said no later than 9:30?? 7 o'clock sound alright, u remember where my house is and stuff
yea i was intending on coming home around then so yea thats fine i will pick you up at like 6:50 - 6:55ish
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
