  • Replies 1.2k
SOooooooooooooooooooo who is going to come tonight. Come on you know you want to i will be rocking up around 7ish having some dinner and hopefully trying to help with trivia but as usual will be a complete disgrace :(
hope to see someone there :D
  • 1 month later...
Well...I guess it's about time to call last drinks,turn the machine off,thankyou linesmen and ballboys: R.I.P. trivia night.
Never mind that Sin' started what I believed was a regular excuse for banter and laughter between friends. Never mind that the trivia girl was usually a good laugh and occasionally flashed some G. Never mind it was the one night you would just KNOW that someone you'd know was shooting pool or desperately tryng to answer the correct spelling for Vladivostok,Russia. Hell,even Dani' in the mighty FTO would come along when she was sick...
Not a single soul tonight made for a depressed me. A real shame,and absoultely NO reflection on a great idea that lead to many fun filled Tuesday nights until now. I loved trivia night almost as much as the people that attended it.
I think it's had a compounding effect, we lost Sin' so a couple stopped turning up, we lost them so a few more stopped turning up.
I didn;t go last night cause i knew purely and simply that we might be lucky enough to get 1 or 2 there.
Jayce: I messaged 'Ric to let you know i wasn't going so hopefully you got that message as i wanted to make sure you didn't get a nasty suprise to find i wasn't there.
It's a true shame, I really do love going, but when you have to start going at 8 just to make sure at least your best 2 friends will be there (J and E) it only leaves an hour and a bit of socialising and when the driving takes an hour, it loses it's thrill.
: sorry Jayce.
A million reasons why most have stopped showing up (last night I worked till after 9), but it shows that it became an effort some ppl no longer felt like making or not as often. I still beleive xxx aint trivial :P
We have a Great opportunity to do something else new and exciting. Im certain there is a heap of enthusiasm amongst us. I'm up for almost anything.
IDEAS PLEASE
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
