  • 1 month later...
  • Replies 1.2k
  • 1 month later...
  • 2 months later...
  • 4 weeks later...
Just quickly,I remember last year at Melbourne Cup time,there was no trivia on(as everyone was too p**sed at the racecourse). However,E and I will still be making an appearance,even if it's only for a feed! Good SAU company is always welcome!
Well,E,me + Gus were there last Tuesday,but as the alcohol from The Melbourne Cup had taken over,there was many a bogan,and a heap of fistfights,so you all didn't miss anything...
We left early,too...
  • 2 months later...
Trivia's back on bitches!
Bullet32 and myself will be there tonight, there will most likely be others there too.
For those of you that are new, it's not really trivia as such.... it's more of an eat/drink & be merry type of arrangement. There just happens to be a trivia comp on in the background.
We'll see any takers out at Jerrabomberra pub around 7:30, don't be shy :laugh:
I thought you would have already known Jayce, I cant drive for a little while no bigie just stupidity. I wasnt even in the skyline. I am happy now to just pull the car to bits and do some things that need doing lol.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
