i had 8 GTR injectors, 6 were out of my car and 2 out of another GTR....but i just sold 4 of them to a 180SX....so still have 4 left if you are interested.....
$200 plus delivery feez which is $14.2 include insurance~~~!!!
i can be contacted via:
[email protected]
or
0432290926
cheers
