as a bit of advice..... a non turbo one is the same - just cheaper
we use them in our high powered sr20s. most above 300rwkws n one even goes as far as 513rwkws
Serious?
Thanks for the tip - that's appreciated and I would never have figured that out. When you say exactly do you mean EXACTLY? ie. straight replacement/bolt up?
I figure if that's the case the non turbo one wouldn't be nearly as thrashed (well.. maybe it is but yeah you know what i mean).
yeah as far as im aware its all the same boltup as it fits a sr20 n the engine doesnt change shape :(
Matt - i couldnt answer that one for u... prob someone like SK could do that tho
AHh yes... RWD please :)
Duncan it's erhm.. slowly getting worse.
N > 1st = rev to 2000rpm if you want it to go nice
1st > 2nd = double clutch or shove in (if shove then then wait 1 second in N before shove and don't be over 3500rpm MAX)
2nd > 3rd = same as above
3rd > 4th = hummmm acceptable but better at 2200rpm or so
4th > 5th = shove, push, straing then shove again
all shifts down need to rev match otherwise it just won't go in (well, unless you shove it).
I must admit however since I put in the redline heavy (*grin*) and drained out the oil that was in there before (which was like water) and actually screwed the clutch slave into the gearbox (as opposed to just hanging off the side) it's stop grinding through each gear :)
I figure getting a box is preventative medicine in this case - not falling out at the track... i might have to get some recon with stronger parts quotes too.. might be the safest option :
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
