My lil nephew is asking for a gameshark for christmas (got a ps2). I figured out it's some sort of a cheat device for the ps2.
I've looked online but it seems you can only get it via eBay (I don't feel confortable buying things through there) or from overseas (which they don't deliver to Australia). So my question is where can I get it from? :confused:
https://www.sau.com.au/forums/topic/56460-help-gameshark/
if it helps at all a game shark is a device where u can get codes for basically any game. they are all number based codes i think. have u tried ordering it through something like EB ( electronics boutique (spelling :S) ordering off the net isn't all that bad just choose wisly. also try looking up info on www.ign.com
best of luck mate
https://www.sau.com.au/forums/topic/56460-help-gameshark/#findComment-1094500
i tell you what man..
if you don't trust e-bay..you can always find someone you know on the other side of the pond to pick one up for you..then send it down under to you.
i think that's probably the easiest way going about getting one for your nephew.
oh yah, my friend has a gameshark. trust me, it works wonders..LOL
https://www.sau.com.au/forums/topic/56460-help-gameshark/#findComment-1098919
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
