Ok...i dont know much about mods just yet,.i have had my line for about 4 months now and am loving every bit of it..i am now onto modding my car.
i have done my research before posting this up,.and had no luck.
my question is.
What does Z32 AFM really do ? i mean,..what are they ? is it really neccessary to upgrade your normal R33 AFM to a Z32 AFM ?
and lets say i am aiming for 250rwkw,.do i need to change to Z32 ? any power gains from it ?
thanks for the help guys...appreciate it.
https://www.sau.com.au/forums/topic/56659-z32-afm-questionspls-help/
im not exacly sure at what rwkw level the rb25 AFM runs out, but mine is pretty close now and im on 180rwkw
If you max out the rb25 AFM you wont make any power past that, so you need a larger AFM such as the Z32
You shouldnt really need one unless your changing turbo
i dont know how to word it properley coz its only what i was told but it has somethin to do with the voltage the z32's read or something, which allows the ecu to read that there is a change in air goin in to, sorry if u still dont understand, im in the same league just "tryin" to explain what i was told...
if anyone else could give a more detailed explanation than me lol it would help
cheerss...ben.
I did my search once again finding what Z32 does..but no luck...i have read a few threads of people having this AFM on their car which mostly has changed their turbo setup.
is it really neccessary to upgrade even if you're using aftermarket ECU like the FC ?
i dont wanna be one of those who put stuff in their engine and don't know what it does.
so anyone knows ?
i could be completely wrong here, but my understanding is the Z32 AFM allows a wider and of air flow to be measured, say for example sake, the r33 AFM reads 1V when 1 cfm/s of air is flowing thru and 5V when 5 cfm/s of air is flowing thru, then the z32 AFM may read 1V when 2 cfm/s of air isflwoing thru and 5V when 10 cfm/s of air is flowing thru
this could be completely wrong and the numbers aren't real just for exmples sake, but thats my understanding of it, this means to ur case
that the ecu can see the extra air coming thru and compensate for it, because when u max out an AFM the ecu won't add any more fuel, or will it ???
Not larger, just greater resolution.
Only required for big power when you max out your AFM and your EFI system can no longer accurately tell how much air is entering the motor.
Not really to do with power, rather A/F ratio
yes thats what i meant, i didnt mean bigger as in size
And most of whats said is correct, the Z32 has a larger scale of tuning so to speak
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
