  • Replies 64
could u post the location of the places these are valid? dun wanna spend $20 worth of fuel for something like a wheel alignment hehe
and also, if we were to buy something worth more than the value of the auction item, can we pay the extra money ?
so for example the service is worth up to $100 but u want them to do other stuff and the end bill is $150, u pay em extra $50?
Sponsor Contact Details
Above is a link to the sponsor details. The original PDF file doesn't seem to be linking to the webspace anymore *mutters*
In regards to the donations.. For the services, they will only cover up to $100 for Automotive Technique and Cosmos Mechanical. Tuff Toys will cover a full service. So yes, if they service comes to $150, you will need to pay another $50 cosmos and Automotive Technique.
Obviously if there are things like, your radiator needs flushing... or gearbox oil needs changing, that won't be covered cause it's not something that would normally be covered in a simple service. Capeesh?
Just reminding people that anyone who posted over hte last two days might have to do so again? I was informed that the Dyno had a bid of $160? Can anyone confirm this and who it was (nick?)
With the forums having to be backed up, we lost a few posts.
Get behind these auctions guys! I need to find the person who put $160 on the dyno.. I'm sure he'll come back in to see if he won!! IF we had that $160 on the dyno, we are $46.35 off the $1000 mark.
Anymore advances on the current bids?
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
