boostmeister had tuned cam gears and s-afc and a few other thing I'm not sure about the 300 rwhp. on many other dyno's cause as we all know some dynos read higher than others.
I know for a fact the cg30 turbo is rated @ 300-320 hp @ the fly wheel it only has a 49 mm exhaust wheel.
but still they are a good turbo I do miss mine even though it was laggy.
meggala
Originally posted by JiMiH
laggy?
damn! :)
is the vg30 much laggier than the standard turbo?
Shit yeah you are pulling out a roller bearing turbo (sorry im not sure about others but i have a vg30 nonbb) with small .48 or similar exhaust housing with tiny wheel now you will be upgrading to somthing with much larger exhaust iun comparison..
Im guessing you wont get full boost till 3500 does this sound about right? I had one on a CA18DET and it didnt give me full boost till about 3700rpm.
As for the other guys I mentioned 18psi as a ball park figure with other mods to acheive 300rwhp from an rb20...But as Inasnt said it is absolute max rating! Id be saving up a bit more and going for a HKS 2540 or the like if i was in your boat Jimih :burnout:
You still have to do cooler first and some engine management
mmmmmm a GT2540 would be nice .... I think I'll just have to stick with the VG30 for a while till I save up more money :)
I got the intercooler today ... now I just have to get it fitted.
That new fuel pump is loud!!
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
