hey !
just bought a t3/t4 turbo
just wondering with the bolt up of this turbo, as im goin to do this myself
and havent done this b4
is there any other things i have to worry about
oil lines etc
and with being able to have internal or external wastegate
which one would be most suitable?
i was thinkin of goin external,
being able to have a custom manifold, more flow and wateva
what max boost could i run
i have stock engine, goin to get a front mount and split dump pipe
done b4 i put it on
is there any good sites relating this too an r33 s1 ?
thanks for any help on this, be much appreciated
baz
https://www.sau.com.au/forums/topic/57108-t3t4-t04e-hyrbid-turbo/
i suggest you get do some extensive research into this before you do any of this yourself as youve never done it before. it takes more than just bolting it on to make it run safe and efficient. Depending on whether the turbo itself already has an internal wastegate or not. if it has not got an internal then you will obviously need to go for an external which means a modified manifold will be needed. also depending on the flange size on your turbo whether the standard manifold can be used or not. The standard sized flange is a t3 flange but dont quote me. piping, exhaust, boost, injectors, management, wastegate are just some of the things you will need to look into. upgrading a turbo usually means modifying oil and coolant lines aswell.
thanks for the reply, and i guess i wont be doin this as soon as i thought
i'll do intercooler and dump first off, also will have to check out prices for custom manifolds
and a wastegates,
and someone that will be able to do all the lines and whateva.
what power output will, or should be able to come from this
say if i ran 14psi, stock engine, 3 1/4 exhaust, pod
considering i will have custom mani, external wastegate and split dump
the turbo is a stage 3 hybrid t3/t4 wet floating ball bearing
brand new !!
thanks for ya help ryan!
out of interest how much was the hybrid turbo?
What are they like?
I just put a Hybrid FMIC on my R33 and it looks tuff and lets me up the boost quite safely. Im happy with it and have noticed a difference in it.
Are the turbos they make good as well?
Do some reasearch and find out weather the new dump pipe will suit your needs.There is no use getting this one and having to get a new one for the t4 turbs.
If the turbo needs an external wastegate then you will need a proper exhaust manifold to house the turbo and external wastegate and a new dump pipe anyway,that will have your wastegate plumbed in.
More than likely you are going to need a new exh manifold anyway you look at it.
With the steel wheels on in you can run good boost.
What version of this turbo did you buy?What was the hp rating of it?Was it an external (ex) or internal (int) gate???
A wastegate that vents to the atmosphere on a road registered car is a defectabled one.
all i know its a stage 3 t3/t4 hybrid turbo
500hp capable of 25psi
we floating ball bearing
.50 a/r compressor
.63 a/r turbine
.57trim
5 bolt exhaust flange
3" inlet diameter
2" outlet
1/8 npt oil inlet
can be used int or ext wastegate
710 bucks brand new
I dont know how to install one of these turbos.But try to contact the person that you bought it from and see if they know.
Basicallly all you need for the install is turbo,dump,water and oil lines braided,because i dont think stockie items will line back up.And a new inlet pipe made from aluminium or mild steel.
If the turbos exh housing has a t3 flange then it will bolt back up to the standard exh manifold.A T3 flange is what all rb25det's have.
FYI:The turbo will only support internal gate on it's own or external gate on it's own not both.The stock turbo in the pic is internal gate.If u need an external gate then you will have to plumb in the external wastegate from the manifold.Most go for a completely new manifold that allows for the wastegate.
But some go for a spacer in between the exh manifold and turbo exh with a pipe plumbed from the spacer from the wastegate.Meh.
Here is a pic of the stock turbo and it's 6 stud dump pipe flange pattern.:cheers: not good for a hybrid t3/t4 turbo to use for a stock dump.Have to get a custom one made:)
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
