Alpine ex top of the range IVA-C800 Mulitmedia Head Unit '02 model
  • 6.5" Screen (no scratches etc..)
  • AM/FM Tuner
  • Inbuilt CD Player
  • Hideaway breakout box, with 2 Video/Audio inputs, 1 AV output (for 2nd screens etc)
  • inbuilt 45wx4 Amplifier
  • Front/Rear/Sub output (4V preout)
  • Remote control
Head unit full specs
Product Specifications:
Ai-Net
  • External Processor Audio Full Control
  • External Processor Preset Function Recall
  • Multi CD Shuttle Control
CD Player
  • 1 Disc DV-S Mechanism
  • 8x Oversampling
  • CD Text
  • CD Text Display
  • CD Text Scroll
  • Digital Servo
  • Disc Play/Pause
  • Disc Title Memory
  • Forward/Backward
  • M.I.X. (Random Play)
  • Music Scan
  • Music Sensor
  • Regulated 1-Bit DAC
  • Repeat
CD Shuttle Control
  • CD Text Display
  • CD Text Scroll
  • Direct Disc Selection
  • Disc Play/Pause
  • Disc Title Memory
  • Forward/Backward
  • Music Scan
  • Music Sensor
  • Repeat
  • T.S.M. (Title Search Menu)
  • T.S.M. Scroll (Title Search Menu Scroll)
General-Head Units
  • 1 Aux A/V Output
  • 2 AUX A/V Inputs with Remote Control Input
  • 3 PreOuts
  • 4-V Non-Clipping PreOut
  • 45W x 4 High Power Amplifier
  • 6.5O FantomFace Mechanism Monitor
  • Audio Interrupt In
  • Auto Close/Open
  • Clock
  • Dedicated Navigation Input
  • Detachable Trim Plate
  • External Audio Full Control
  • Fader & Balance Controls
  • Integrated NAV/Audio Remote Control
  • Loudness
  • Navigation Audio Mix
  • ODigital-ArtO Spectrum Analyzer
  • Power Antenna Lead
  • Remote-on Lead
  • Screen Saver
  • Separate Bass & Treble Control
  • Subwoofer Level Control
  • Versatile Link
  • Volume Control
  • Wireless Remote Control Included
Tuner
  • Auto Memory
  • D.A.P. (Direct Access Preset)
  • FM Station Indicator
  • Local/DX Selection
  • MaxTune SQ Tuner
  • Preset Address Indicator
  • Preset Stations (FM:12/AM:6/DAP:6)
  • Station Title Memory
  • Title Search Menu
  • Title Search Menu Scroll
  • Up/Down Seek
AM Tuner
  • Tuning Range : 530-1, 710kHz
  • Usable Sensitivity (IEC Standard) : 22.5/27.0 (uV/dBf)
CD Player
  • Channel Separation (1kHz) : 85 dB
  • Dynamic Range (1kHz) : 95 dB
  • Frequency Response : 5-20k ?1 dB
  • Signal-to-Noise (S/N) : 95 dB
  • Total Harmonic Distortion (THD) : 0.008%
  • Wow & Flutter (%WRMS) : B.M.L.
FM Tuner
  • 50dB Quieting Sensitivity : 1.3/13.5 (uV/dBf)
  • Alternate Channel Selectivity : 80.0 dB
  • Capture Ratio : 2.0 dB
  • Mono Usable Sensitivity : 0.8/9.3 (uV/dBf)
  • Signal-to-Noise (S/N) : 80.0 dB
  • Stereo Separation : 45.0 dB
  • Tuning Range : 87.7-107.9MHz
General-Head Units
  • Bass Control Range at 30Hz : ?15 dB
  • Continous Power Output (Note 2) : 19W x 4
  • Maximum Mounting Angle : 30! from Horizontal
  • Maximum Power Output (Note 1) : 40W x 4
  • Power Requirement : 14.4(11-15) V.DC
  • Pre Output Voltage (Before Clipping) : 4 V
  • Treble Control Range at 10kHz : ?15 dB
  • Weight (Monitor Section) : 1.7 kg (3 lbs. 12 oz)
  • Weight (Tuner Section) : 1.6 kg (3 lbs. 8 oz)
Monitor
  • Number of Picture Elements : 336.960 pcs. (1,440x234)
  • Effective Number of Picture Elements : 99.990r more
  • Illumination System : U-Shaped cold cathode fluorescent tube
  • LCD Type : Transparent type TN LCD
  • Operation System : TFT Active Matrix
  • Screen Size : 6.5O
Remote Control
  • Battery : (2) AA size
  • Dimensions (W x H x D) : 1-3/4O x 1-3/4O x 5-1/4O
  • Model Number : RUE-4165
  • Weight : 70 gr (2.5 oz)
Price - $1000 (the DVD player that was being sold with this head unit has since been sold - this price is for the headunit and reciever only)
some pics
http://images.platinum.net.au/categories.php?cat_id=60
if you sell wann upgrade to mine i got a ivad300 (latest alpine pulse touch ,dvd bla bla bla)
selling as bought a ute dont want it in there was in my crx for 1 mth used with remote so sreen perfect and unit perfect now back in box. askin 2300 $700 off new
Will sell both together for $1700 FIRM! If I dont get 1700, I wont sell it... simple as that (as I am only selling to upgrade).
come on guys, i can totally vouch for this unit and it's condition (i sold it to prank not long ago, and i have always treated it with the upmost respect), it is a fantastic little MM Headunit and looks great in the skyline!
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
