Datalogit worked no problem'o. Must have been a newer version of the software Gav. It's all good, thanks for the ecu by the way mate :D
No sweat Rev
btw - did Lumpy or Ken confirm that it's NOT the Pro version? I was never sold to me as such (nor did I sell it as a Pro version), but it has the "PFC PRO" sticker on it?
Interesting...
driver,
front pipes and 3 inch exhaust, Power FC, Tomei 260deg 9.15mm lift cams, 10/11psi of boost, Blitz pods (although they are sucking hot air at the moment). Although it doesn't alter the dyno reading the car has also got lightweight Trust pulleys and has had the belt driven fan replaced with a 16inch electric thermo fan.
The factory engine and turbos have done over 236,000kms, so it's pretty good for a grandad engine.
rev210,
wot your plans for the future for the gtr? do you plan to go further with the development etc and if so wot did you have in mind. Cos there alot of potental there your yet to tap into but with a tired motor i can understand not pushing it to far. the beauty of the rb26 is that it does cost alot to really get some awesome rewards. Hope to see you round soon .
pete
Hi pete,
There is an oil cooler and filter relotaion kit waiting to go in (maybe today) to get some of the heat out of the motor and help it live a little longer. It's a nice kit only $600 or so new with stainless braided lines and 15 row oil cooler.
Hi pete,
cool sound like a good idea ,i been looking for a desent oil cool kit for awhile can i ask where you got it and wot make it is, wot sign are you using to tell you the motor is tired may i ask (low oil pressure, or compression etc) do you hope to rebuild soon.
pete :rolleyes:
ha are you going to this xmas do on thursday cos it would be cool to catch up with a few of you guys for a beer and a chat .two more days and i'm back on dry land woohoo :headspin:
Hi Pete,
The oil cooler is one I bought from Sal at 'Shift' over east ( one of the SAU advertised sponsors ). Worked out to around $625 delivered. So far the only measure of how tired the motor is is the kms. I haven't got around to measure the compression yet. Oil pressure is normal.
I am going to try and get to the christmas bash but, this week is a killer for me work wise so I won't know till very close to the day.
Steve,
I reckon Aidwin secretly wants to kill his turbo's tho so he has a good excuse to get bigger ones I bet :)
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
