Hey people i just got my 89 R32 4 door auto.
Some questions.
1. It has this spoiler at the front that can come down when you are parked with the handbrake up????????????????? Whats this for????????
2. Power button?????????
3. Overdrive button??????????
4. Hold Button??????????
If anyone knows what all these are for please let me know.
https://www.sau.com.au/forums/topic/57614-my-r32/
Some questions.
2. should have power/snow button - power is meant 2 give u quicker gearchange..minimal difference tho & snow is 4 use in..snow in japan but in australia - when raining..will actually take off from standstill in 2nd gear 2 give more traction in poor road conditions.
3. overdrive is just 4th gear push in when over about 80kms..otherwise should leave alone when not on highway driving to have more acceleration.
Those other 2?? No idea sorry, maybe unique 2 4door or 32 model..mine is 33.
https://www.sau.com.au/forums/topic/57614-my-r32/#findComment-1110560
hold button is not what the previous guy said ...but its basically for economcal driving ...it likes the reverse of the power button......
where the power button holds the gear longer and revs higher and changes quicker .....hold does the oppsite ...good for highway driving etc....
well this what is was like on the Nissan Pintara Ti auto ... i dont see why it would be any different
https://www.sau.com.au/forums/topic/57614-my-r32/#findComment-1110930
The spoiler comes down when you are parked??? Or there is a button to make it come down? Because normally it would come down at I think its about 100km or something, the button is to just keep it down. From memory anyway, a mates brother has basically the same car.
https://www.sau.com.au/forums/topic/57614-my-r32/#findComment-1111285
kkkkkkkkkkkkkkkkkkkkkkkkkkkk
why do you keep doing these gibberish posts in peoples threads?
back to topic
i have found using the overdrive button during normal driving might save you petrol... i fill up one day later when i leave it on for a week... I should properly test that one day.
https://www.sau.com.au/forums/topic/57614-my-r32/#findComment-1116499
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
