Hey people i just got my 89 R32 4 door auto.
Some questions.
1. It has this spoiler at the front that can come down when you are parked with the handbrake up????????????????? Whats this for????????
2. Power button?????????
3. Overdrive button??????????
4. Hold Button??????????
If anyone knows what all these are for please let me know.
https://www.sau.com.au/forums/topic/57614-my-r32/
Some questions.
2. should have power/snow button - power is meant 2 give u quicker gearchange..minimal difference tho & snow is 4 use in..snow in japan but in australia - when raining..will actually take off from standstill in 2nd gear 2 give more traction in poor road conditions.
3. overdrive is just 4th gear push in when over about 80kms..otherwise should leave alone when not on highway driving to have more acceleration.
Those other 2?? No idea sorry, maybe unique 2 4door or 32 model..mine is 33.
https://www.sau.com.au/forums/topic/57614-my-r32/#findComment-1110560
hold button is not what the previous guy said ...but its basically for economcal driving ...it likes the reverse of the power button......
where the power button holds the gear longer and revs higher and changes quicker .....hold does the oppsite ...good for highway driving etc....
well this what is was like on the Nissan Pintara Ti auto ... i dont see why it would be any different
https://www.sau.com.au/forums/topic/57614-my-r32/#findComment-1110930
The spoiler comes down when you are parked??? Or there is a button to make it come down? Because normally it would come down at I think its about 100km or something, the button is to just keep it down. From memory anyway, a mates brother has basically the same car.
https://www.sau.com.au/forums/topic/57614-my-r32/#findComment-1111285
kkkkkkkkkkkkkkkkkkkkkkkkkkkk
why do you keep doing these gibberish posts in peoples threads?
back to topic
i have found using the overdrive button during normal driving might save you petrol... i fill up one day later when i leave it on for a week... I should properly test that one day.
https://www.sau.com.au/forums/topic/57614-my-r32/#findComment-1116499
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
