no it won't
yr bonnet need to mod as GTR grill design is different
and the guard is not wide enough
if u really like GTR front bar u can try east bear
http://www.east-bear.co.jp/aeroparts/m-pie...e/R34f-spo.html
http://www.e-aero.jp/aeroparts/m-piece/R34.html
no it won't
It will fit if you don't mind doing some work on the bonnet...there is a Japanese site showing step by step how to fit one.
The guards are wider, but the amount that the bar flexes in doesn't look bad, as it's only a minor geometry change.
I have a R34 GT-R front bumper and HKS Kansai C/F Hood on my R34 GT-t.
Assuming you have a GT-R hood, the R34 front bumper does fit with no mods as long as you get the upper grill support brackets that bolt to the headlights as well as the cross bar that the top of the bumper attaches to. The stock GT-t bumper re-enforce will work with some slight trimming I believe. I opted for a GT-R bumper re-enforce (light weight allumi) so it fit like a champ.
As far as the attaching the bumper to the fenders, only one bolt hole will line up so you can either toss the plastic re-enforcement piece that the front bolt goes through and use rear bolt to hold the bumper on each side or re-drill the forward hole in the bumper to the correct position. I used the rear bolt only as I was too lazy that day to re-drill the bumper. You will end up with the tips of the bumper about 4mm past the end of the fender wheel arch, but it is not too bad. There will also be a small gap between the headlights and the bumper at the corners, but in all it looks tits hot!
As for the hood you need to buy GT-R hinges and a GT-R hood latch support to make it work. If you get an HKS Kansai hood you can "mod" your GT-t hinges to make them work but you need a butt load of washers to bring the hood up to the correct height in the back. You will need to drill a new hole in the GT-R hood latch support to bolt it to your lower radiator support frame on the car but it is a piece of cake.
I will try to get some photos of my setup for you guys if you want.
If you have any questions feel free to PM me I will be happy to help you out.
where might this Japanese site be?? :(
where might this Japanese site be?? :D
http://homepage2.nifty.com/ma2kun/ER34r.htm
Here is the site for modding the GT-t hood and installing the GT-R bumper. If you save the photos to your HD and open them up they are a bit bigger than what is on the website.
This is the site I used for reference when I put my bumper on.
I will be taking some photos tomorrow and will post them for you guys.
In the mean time here is a photo of a GT-t with a GT-R rear bumper. (Not my ride though I got this pic off the internet somewhere if it’s a forum members ride I am sorry for scamming your pic)
Looks great! ;)
Hey, another Japan member - have you visited the Japan section? :)
Nice to see someone else with a non-GTR R34 in bayside blue - not many of us about!
Q: How'd you manage to get a private plate? I mean, I someone doubt it was a coincidence you got "34" :) :)
Dave (In Yamanashi)
Looks great! ;)
Dave (In Yamanashi)
Hey thanks man!
The private number was easy. When I bought the car from NISSAN I asked for the number ”. . 34”. It cost like 4000 yen extra, but anyone can do it when you register a car.
I have had the car for a year now and I did the bumper and hood about 3 months ago but these are the first new photos since the front-end change.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
