Hi Guys,
I'm trying to find out what a pair of tail lights are worth and how hard they are to find for these two models skylines.....
The ones I'm talking about are the jap spec ones different to the ones we saw here.....
Are they rare?  Expensive??
Cheers,
Simon
Jap Hr31 tails lights are getting very hard to find indeed, and would fetch a fair price (guess around $170-$200 per light)
Don't know about the Dr30 taillights, but would expect them to be harder to find and most likely more expensive aswell.
There's quite a few people who have given up on getting the old school hotplates for their 31's... If you are thinking about getting a few sets sent over, make sure you get the centre garnish as well. :(
I don't think you'd have much trouble selling them provided they are in reasonable condition.
the late model dr taillights are similar to the S3 r31 ausi taillights ( dr30 ones don't have the smaller section for the indocators and reverce lights at the bottom) next to imposible to find here, the earlier ones the stove tops ones are not quite as hard to find and i wouldn't pay more than $200 for a set unless they were brand new, hint hint....thats what the stove tops look like at night? sort of the like the passage lights pictured about...
damm and i have no money at the moment its always the way... TUFSSS, if your mate can get late model DR ones in that condition at about the same cost them i'd say there would be a few of us here alone that would jump at the chance!
i bought a pair of HR31import lights not long ago ...simply coz tehy were cheap ..but i'm not a fan ..i ended up swapping them for a good pair of Ser3 31 lights instead...
i paid 210bucks including the center garnish and postage from brisbane for them.
I've seen the DR30 ones with the two round circles inside the squares, are these local or JDM?????
All DR tail lights are JDM, i beleive the ones you are talking about there are the S1 tail lights...
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
