Hi Guys
My mate has just landed a few thousand hybrid intercoolers. 600mm x 300mm x 76mm. These coolers are exactly the same design as the original hybrid manufactures. The specs you see on those intercooler also applies here.. I will post up some spec soon.
Here are the specs
Attrictive polished aluminum look
3" inlet and 3" outlet pipes for high flow
Low pressure drop 0.2psi at 15psi of boost
80 psi for up to 800 horses
Made by lightweight but strong material. Same Structure and material used as famous "Hibrid" Intercooler. Weight ~8kg
All coolers have been Pressure tested.
15 bars core design. For more efficient air flow over the older 16 bar design.
2 sizes
Size: 600mm x 300mm x 76mm
NEW PRICES
up to 5 buyer: $330
5 to 10: $300
10+: $295
Size: 450mm x 300mm x 76mm
NEW PRICES
up to 5 buyer: $325
5 to 10: $295
10+: $290
p&h: ~$25 to the east side of australia and $30 to the west.
As seen in the picture the cardboard box has polystyrene strips to protect the fins from transport damage. The cardboard box is even double up in places for extra strength.
Payment must be by Direct Deposit.
Local Pickup is available. Save p&h..
If you have doubt about buying from this group buy do a search for other groups buys with my name. Im sure you will find out quickly Im an honest bloke :D . Also if for some rare reason I can't get the parts and you have already transferred money to my account your money will be transfered back to your account straight away!!
Piping will be available soon for this intercooler. Soon I mean ~1 month..
https://www.sau.com.au/forums/topic/57896-hybrid-intercoolers-group-buy/
  • Replies 46
when is the end date? and how much will piping be?
Don't have an end date for this will be in around 2 weeks, depends on how many people are interests. I would like to get ten.
piping will be ~400 I believe
Update the prices... Check em out..
I will end this thread when I have 5 people. If I have an influx of buyer then 10. But there is a couple of people waiting right now so I really want to close this one and move onto intercooler group buy number 2..
I just bought a intercooler for 51jay. Really really nice cooler!!! beautifully made! The welds on it look so strong!! I'll post up a really big picture for you all to see. When he gets the cooler Im sure he wont mind you asking him. I hope!!
FAQ WARRANTY.....
If the cooler is damaged from a factory fault my supplier will replace it. No question asked. But I alway check over all the parts before I purchase them.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
