Hey guys,
I bought some spitfire ignition coils from nengun, gave them to my tuner to chuck in, and they fit just fine.
Probelm is they dont fire, then with the terminals swapped over they just contiunously arc.
I know there is different packs for S1 and S2 R33 Lines, but my car is definately a series 1, although the ignition setup looks different to my mates s1 93 model (mine is 95).
Is there a way to find out FOR sure if my motor is a S1 or S2, (either visually or on the compliance plate?)and what are the odds of being able to make the coilpacks work in my motor if indeed is a S2.
I bought the S1 packs.
Any feed back greatly appreciated cheers.
https://www.sau.com.au/forums/topic/58197-spitfire-coil-pack-issue/
Nah thats the thing thats different its not there on mine but is on my mates, just did a bit of browsing at http://www.perfectrun.com.au/performance%2...systemframe.htm, according to that i shoudld have the 005 coils, i have the 001's. Is there anyway I can change to an igniter pack to get them to work, i cant imagine the head ache of trying to send them back to Japan?
Sweet ok, where can I get one of these modules? I live in sydney. Any instructions you could give me would be really helpful.
BTW cant send em back, cause the guy from nengun actually emailed me to ask me what series motor I had, he was too helpful, I couldnt shaft the bloke now.
Umm EDIT : not running stock ECU am running EMS stinger.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
