Just thought I'd share my s13. I got her back yesterday. All it has so far is a POD and a short shifter. Doing the exhaust next then intercooler and a bit more boost. I don't know why the sr20 fanboys pay this engine out. I can't get the smile off my face.
when i had my rb20 in my old car (s13 hatch) i found it to be boat loads of fun.
now the car (s14) sounds like a pissed off supra when rowing thru the gears, im glad i never did go the sr20 route its so played out and the rb20 just has so much soul to its ehxuast note and loves to be thrashed.
to be honest i dont think i ever had more fun than the stock rb20 in the s13, better ic would have made it better thats for sure.
just wondering.....
i have a rb20 with a hks 2835, microtech, cams, basically everything, it dynoed @ 205kw at 17psi....
does this power figure sound a bit low??
.... sounds like some ppl are making more power with less mods!!
just wondering.....
wow, full standalone and not making 260rwkw?
is it just a poor tune or lack of igntion to make things happen?
i made that 387rwhp pull on stock ecu that i had chipped for 550 injectors and z32 maf, other than that it just has a hot timing map and we added some fuel with an emanage (which sucks btw....).
perhaps a new tuner is in the picture?
yer i was expecting at least 220-230 @ 17psi..... bit disssapointed to say the least.... it feels like the power really drops around 6-6500 rpm when it should still be climbing! it feels slower than my old rb20 with a r33 turbo on it because of the lag.....
engine crap in detail:
microtech lt-12/handset, 3" zorst front 2 back, 3" cooler piping,
blitz sbc controlling boost, 33gtr pump, sard 550cc injectors,
hks 254 inlet 8.5mm lift (?) tomei procam exhaust 264 9.5mm lift(?)
hks cam gears1 and 2835 .60 compressor housing, dunno turbine side
all i can say is its not the number of 205kw that dissapoints me, its the way it feels, and to drive, it has a really narrow powerband, and doesnt pull all the way to redline.. its been tuned by 2 different ppl, very reputable, my last option is to go to tilbrooks but that means more $$$
it wouldnt be the zorst restricting it would it?
what cooler piping size would be recommended>?maybe 3" is too big/?
i hate cars now. they make me broke.
hi peeps mmm what do u think my rb20det will make on the following mods?
6inch k&n
turbonetics t3/t4 60-1 t3 stage 3
q45 90mm afm
600x300x76 fmic
s/s high mount exh manifold
44mm tial wastegate
full 3inch exhaust
modded intake plunem(moved t/b)
port n polished head
modded cams
599cc injectors
500hp fuel pump
turbonetics godzilla bov
apex power fc + boost kit
i want to run upto 18psi
will it make 300 rwkw? :)
i had a similar problem on my rb 20, turns out it was a blocked rear muffler. are you having any trouble gettiing boost ?
hey guys, i get my 32 tuned in 2 weeks, so ill post up the dyno sheets when its done, hoping for 300rwhp with the following mods,
high flowed turbo
hks intercooler
3.5 inch apexi exhaust
gtr injectors
bosch 040 pump
tomei poncams
power fc with boost kit
blitz intake
running 18psi
hey drifter, i dont have any problems making boost!
i have just found an exhaust leak where the turbo bolts on to the manifold, i fixed that up, and now it feels smoother to drive, but i cant really tell if its any better...
thats a good idea tho, ill check if the mufflers blockd, thanx..
well that is certianly very curious as to why its not making power because with that setup i would expect a fairly fast spool and good powerband.
do you have a cat on the car? if you do perhaps it is melted shut.
on my car the charge pipes are 2.5" and my exhaust is 2.5" to 3" back (turbo elbow is 2.5").
Drop the exhaust at the inlet to the cat and do one quick power run on the dyno. That will tell you whether it is the exhaust or not. For 20 minutes and $50 well spent.
:) cheers :(
Edited by Sydneykid
If you don't want to spend a great deal trouble shooting look at Blackwood auto and dyno. They only change $35 for a power run vs $80+ from other workshops.
Get them to throw it on their hoist, drop the exhaust as SK has stated, quick power run. $max 100 later I would say the exhaust will be either ruled out or culprit.
If Blackwood can't get you in I would say Boostworx.
u guys mean drop the exhaust completely off the turbo and do a power run with the exhaust straight onto the firewall!!?? SAFE!
the cat and muffler arent blockd at all... the cat is hollo-spec.
blackwood auto ey$35 is a very good price....
i have tried boostworx, sean is good $$wise aswell
the only other thing i can think of is the dump pipe looks so dodgy, its almost home made, but it is 3" so there shouldnt be any probs..... maybe it just comes down to the tune
well by hollo-spec i meant hollow, but it is somewhere in between 2.5-2.7" cos it does look like the stocko with flanges welded on to join up with the 3" piping.... i didnt know this b4! i just guessed it was 3"
so my yer, zorst goes 3" to 2.5 to 3" but surely it would only cause minor restriction...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
