hi im trying to get a graph up... umm the tuner reckoned he couldnt stop it knocking at 18psi no matter wat he did... thats y its only 16, thats weired aye.. its alittle laggy
Well id be inclined to run a Bosch fuel pump, and run the std manifold. Pinging at 18psi seems a little strange...did he suggest the reson why it was pinging..
he said i should get some plugs a heat range colder...
are u talking about a standard exhaust manifold?
they just cheap weld n grind cams, standard cam gears..
a strange thing is the cas if nearly fully turned anti clockwise (Advanced?)
I would most definitely be checking the cam timing. Ensure it has been setup correctly and then drop a set of adj cam gears on it and see how u go.
How is the power curve when it wants to ping? Does it want to only ping at a certian rpm range? i.e in my case 4000rpm
I have had valve float issues where i bumped boost up and it would always want to ping at 4000rpm + the power curve would go flat from then onwards.
The last I highly doubt. But a few things to look at.
Hey RB power...what is your car like to drive on the streets?
tail happy?
Do you have any suspension/brake mods to match, 238rwkw is alot to stop with standard brakes :woot::blink:
Edited by bigtim11
just quickly....
whats everyone got their rev limiter set at??
since i got the highflow and having full boost at 4000rpm i hit the rev limiter alot!!!
i just dont feel power loss to change gear
street, 6800rpm
track 7500rpm
roy uses a nice rev limit
just quickly....
LOL...i keep mine at around 8,300rpm. I dont rev 3rd and 4th that hard, but i sure do rev 1st and 2nd gear out to make sure that when i grab the next cog i have as many revs on board as possible. The difference between 4,000rpm and 5,000rpm on my engine is proabably about 100rwkws so worth revving out the lower gears to fall into the meat of the power curve
If your turbo can flow the air, the std cams dotn seem to fall off too abruptly....mine still feels as though its pullign pretty well at 8,000rpm. i thnk it makes about 210rwkws at thoe revs?!?!?!
got the same problem as roy, need to keep the revs nice and high to bypass the lag. mines set at 7500 and is still climbing rather well. cams would definately help but might look at raising it another 300 or so.
i was revving to 8.5 on the old motor before she went.
proly will take the rebuild to a max of 8.3, but this time round with uprated oilpump and valve springs to suit.
gotta remember that rb20's are short oil drive motors so the posibility to destroy the oil pump is very good at high rpms/hp.
tail happy?
Do you have any suspension/brake mods to match, 238rwkw is alot to stop with standard brakes :O:)
hey it seams to be ok alittle loose...lol....stock brakes and suspension apart from lowered springs and drift pinapples lol
my revs are set a 7000 rpm
what year was car? and how many km had it done before it let go?
also, were u driving it everyday at 8000+rpm?
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
