Well I just installed a Boost gauge and a 2-Stage Turbo Smart controller.
Stock boost was running 5psi and spiking to 6psi between 6000-7500 rpm's.
Now running 10psi low boost, 12psi hi boost with no spike.
The boost seems to come on lower down in the rpm.
I think I have just become a boost freak........what a rush.
BTW a big thanks to 51Jay and Co. for helping me put it in.
https://www.sau.com.au/forums/topic/5832-oh-the-joy/
So guys, running stock intercooler on the car? Are you getting the big slump in boost around 4-5000RPM like I hear the R33 will do if theres no aftermarket ECU? Or is that only when going over 12PSI?
Hmm... I might go for a quick cheapo boost upgrade while I save up for my FMIC, PFC and AVC-R if the drivability is still good.
Need to get my HiTech exhaust ordered and on there.. stock system is strangling the engine I am sure :)
https://www.sau.com.au/forums/topic/5832-oh-the-joy/#findComment-88419
I've got a blitz dual sbc type s. It electronically controls the level of boost, I've got 2 settings; 0.6 bar and 0.8 bar. I use 0.6 bar for most of my daily driving and especially in the warmer weather as I'm still running the stock cooler (I've got a Trust front mount on its way). I only run 0.8bar mainly at night when its much colder. I cant stress how important it is to back off the engine if you've got it on a high boost setting and you hear detonation (it sounds like something rattling in the engine, like marbles) cos if you keep your foot buried you'll be rebuilding that engine :)
Rob
https://www.sau.com.au/forums/topic/5832-oh-the-joy/#findComment-88615
thats what im affraid of and whats keeping me from running more boost on mine as i cant really afford to be rebuilding the engine.
I get my boost guage this week and will also get a bleed valve... i want to run about 9 - 11psi until my GTR FMIC gets here from Japan.
At present the only mods i have are a POD Filter, CAT Back and Re-mapped ECU.
https://www.sau.com.au/forums/topic/5832-oh-the-joy/#findComment-88619
definately take it easy on a hot day... alternatively you can do other things to reduce intake temps (the main thing causing detonation on your setup) by installing a cold air partition for the pod filter
i cant see how anyone would really want to thrash it on a 30degree day, so nice for cruising!
https://www.sau.com.au/forums/topic/5832-oh-the-joy/#findComment-88692
Intake air temp on a hot day on the move is usually around 40-43degrees. Sitting in the staging lanes on Wed night it was running 55-63degrees at the end of the 1/4 mile it was back down to 42 degrees. A bit of a burn out brings it down from around 50-55 to 45
https://www.sau.com.au/forums/topic/5832-oh-the-joy/#findComment-88728
slayer, over 12psi on the stock cooler is bad news. I used to drive around with 10psi without a s-afc, and there was no getting past the slump in power (not boost) at 5000rpm. Some ppl don't have the same problem, though. Seems every R33 ecu reacts differently.
rob77, whats the trust fmic gonna set you back, including fitting and piping?
https://www.sau.com.au/forums/topic/5832-oh-the-joy/#findComment-88779
Unsure yet cos it hasnt landed and the workshop is unsure what price they paid for it. When I ordered it the exchange rate was 1aud to 64yen, when it shipped (about 1.5-2 months later) it was 1aud to 68-69yen. Plus you got GST and import duty. Plus it was there 2nd dearest kit for a R33 gts25t, the dearest one includes a intake plenum so that the return pipes can come up the right hand side of the engine. Just the intake plenum is about $1500.
Rob
https://www.sau.com.au/forums/topic/5832-oh-the-joy/#findComment-88834
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
