Hey guys i was wondering if anyone has a basic DIY for changing the clutch and if they dont just some basic things to look out for. I have a feeling that my thrust bearing may need replacing but obviously to get to that i need to get to the clutch. So yea we did it on my sr20 before but that seemed alot easier than what this will be. anyways if you could help out i would appreciate it
oh its a rb25det from a s2 r33
https://www.sau.com.au/forums/topic/58320-diy-changing-clutch/
It's really easy providing you've got a hoist (for g/box) and IS time consuming ..
Slightly more awkward than the SR as theres a little less room to work around the bell housing/bolts but .
Disconnect your battery
Start with the usual and remove the gearstick (circlip) then unbolt the prop shaft and have a catch can handy for all the box oil that will drain out of the rear, you might want to re-use this oil also.
Loosen the frontpipe off the exhaust system also which provides a little bit of leaverage to allow the engine to rock.
At this point I'd advise using your hoist under the gearbox to support the weight while you remove the bolts around the gearbox mount. Then slowly, lower the hoist which will allow easy access in undo-ing all the sensor wiring off the gearbox. Use a small flathead screwdriver for this as they can be very hard and brittle after many years in the land of nippon. :rolleyes:
At this point the hoist should be supporting the entirety of the weight apart from the bell housing. Undo all the bolts off the bell housing and push the starter motor aside.
There is limited room to actually wiggle the box out like I mentioned before so be careful with this and do not force it. You'll find that it'll be necessary to slightly roll the box around a few degrees to clear the starter motor housing of the firewall (on the bell housing as you probably know).
At this point the box should literally drop out slowly as you lower the hoist. Then simply roll the hoist back to remove the box completely and presto, it's done.
If you want any specifics let me know :P
hey jengi thanks heaps for the advise that sounds like the majority of what i needed to know :rolleyes:
yea taking the sr20 apart was a bit of a bitch the way we did it eg no hoist lol we wont be making that mistake again.
and once again cheers Jengi really appreciate the help
I have done a handful of skyline clutches on the ground. I just advise anyone of concidering doing their clutch without a hoist. The box is quite heavy and large on a skyline and it really just isnt worth the pain and well danger of doing it under the car, from now on i will only do them on a hoist with a trans stand.
I do them on the ground all the time , this is what i do .
Jack the car as high as possible , put stands on all corners then do all the unbolting as jengi posted , i let the gear oil out of the box first though . When all the bolts are undone , i leave a couple on the bellhousing , i use a trolley jack , on the gtr or any 4wd i tie the the box to the jack ( use chain ) ,undo the last 2 bolts on the bellhousing , then lower the box to the ground . If i have clearence problem ( getting it out from under the car ) , i either get another jack and jack the car heigher or i drop the box on a little creaper like trolley and bring out like that .
Of course if you have a hoist and a transmission jack its heaps easier .
  • Thanks 1
  • 4 months later...
I'm thinking of changing my clutch in the next few weeks. Few quick questions...
Do you need a special tool to align the clutch?
How many litres of fluid does the transmission need?
How long would you expect it to take?
You do need something , a broken shaft will do the job .
Trany takes about 3.8 lts .
Time depends on your skills and tools you have .
Done this before.... 1st time was piss when we didn't change the clutch. As soon as you move the clutch plates and have to realign them and its multi plates it gets tricky.....esp when ur doing it on the ground. We had trouble getting the spline to go through the plates as we could'nt get the angle right.... got the old man to come up and help and went through 1st go :confused:
Cheers.
Also, I'm thinking of just changing the clutch plate. Is this worth the effort or should I replace it with a whole new kit? I dont really want the pedal to feel heavier than stock...
Why you want to change the "just the clutch plate " , is the clutch slipping ? if yes dont bother do a complete job , if no dont bother taking it out until it starts slipping .
by clutch plate do you mean the thrust bearing ??? if so i would do it thats the only reason i was going to drop the box out to replace that but i have since realised it is not worth the effort.
Thrust bearing is just that a bearing , clutch plate is the round thing with the friction material on it , so no 2 different things .
Obviously its slipping. Even in 5th at 100km/h, before it makes full boost, it slips.
After doing some reading it seems that changing just the clutch plate provides more 'bite' while retaining the factory feel of the pedal (and its cheaper). Is this true?
If it slips , bite the bulet take the box off and replace the whole thing .
You dont have to use a different pressure plate , you can use a Nissan one if you like ( i wouldnt though ) .
By just changing the clutch plate now , you are going to have to pull the box down again to replce the pressure plate , clutch plate and thrust bearing very soon.
The reason its slipping worn clutch plate and pressure plate or to much power if not stock.
  • 1 year later...
ok sounds hard but eazy at the same time to change the clutch.
atm i only have the money to get a decent clutch and dont have money to pay someone to install a clutch.
when dropping out the gear box does it slide off the drive shaft or dose it stay connected and it just dropps down to give you access to the clutch??
if someone has pics of what to undo would be help full or a site that gives more details
thanks
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
