hey cheers for the comments :(
hey tiger im not sure exactly because i bought it already lowered, i found the springs are apexi and yellow but shockies r stock nissan ones, sorry cant give u more info :rofl:
ill measure it when i get the front struts back on and that wont be for a week or so :rofl:
cya
hey happymeal yep i take all the photos myself :rofl:
latest update on the stag 26 conversion:
we have cut a 4" hole in the firewall to recess the clutch master vacuum booster into the cabin abit to clear the engine :)
pedal box is mounted and lines up perfecto with the other pedals :(
got the front struts off atm, and repainting all the underside of the gaurds, and struts/suspension stuff to clean it all up. getting the bonnet latch, radiator mounts and a few other bits and pieces chromed while they are off too cause they look like shit atm.
took a photo of the suspension springs and shocks, ones cleaned and ones how it looked when they came off the car :D
26 will be test fitted next weekend to check clutch master clearance and try out my new baffled enlarged gtr sump i just got :aroused:
gotta move the power steering resoviour to the front so i can fit two 3" intake pipes on the inlet side :D just needs two longer hoses (thankfully it aint the metal lines i gotta change)
gotta make the front pipes from dumps/cat convertor after that and then sort out the handbrake using a r33 one probably, then the tricky wiring and stuff is gonna be sorted by hyperdrive motorsport thankfully :D
so around end of january and it should be goin if everything goes to plan :rofl:
cya
Brad
oooh baby cant wait till you take the beast down to the track for a run down the quarter she should reel off a fairly impressive time ;)
what other mods are planned?
hey mate well plans atm are
rb26 engine
gtr 5 speed
twin plate clutch
highflowed turbos (stock housings, bigger wheels)
sard 700cc injectors
twin 3" k&n pod filters
3" cooler piping
3" intake pipes to turbos
bosch motorsport 044 fuel pump, and better intank pump (not sure what yet)
gtr intercooler
autronics smc ecu :rant:
custom BOV
oil catch can
external oil filter kit
enlarged and baffled sump
in the vl it made 350rwhp only revvin to 7200rpm, and can rev to 8500rpm but i told him to be easy incase something is worn and i really wanted to use it abit b4 i blew it up :rant:
thats the stuff i have atm from the vl so next upgrades are...
apexi or similiar 100mm+ cooler
hks 2530 turbos
with those 2 mods alone my tuner reckons power will go from 350rwhp with highflows to 450rwhp with 2530s and cooler, boost :(
and the 2530s will be more responsive than the highflow turbos as mine are slightly laggier than stock gtr ones and hks 30s r the same as stockies :headspin:
so in the vl it did 12.0 @ 118mph (low 11s roughly) thats on slicks too.
with 4wd it should be a 12 second car for sure :) and with the 2530s maybe 11s on street tyres is possible :)
sure will shock the local hsv/xr6T guys :rofl:
a volvo shaped wagon eating there 80K hsv :aroused:
thats enough from me
cya
Brad
dont forget i want a ride brad :(
gary mate you will hear from me when its goin and ill take u for a spin :headspin:
also tomorrow im test fitting the rb26 engine in for the first time :( to check clutch booster clears the plenum and then we gotta make new exhuast from the 3" dump pipes (already made from VL install) to the single 3" cat back system on the stagea at the moment, so we will run twin 3" upto a merging pipe and into a single high flow cat or one of those really $$$ ones they tested in a recent zoom or HPI magazine that flowed heaps better than normal high flow units.
piccies to come and info as it happens
:P
Brad
Looking good so far.... Also looking forward to seeing you out and about on the streets in the future....you need to bring it to a SAUWA event in future so I can check it out.... Always been interested in the Stagea's and their potential :D
  • 3 weeks later...
no worries gary :cheers:
and yes ill be cruisin in the future for sure :)
recently put 4wd sump onto engine and installing engine in bay for final time tomorow :) had to remake the front turbo dump pipe to clear the passenger side driveshaft on the sump.
as i said in other post the handbrake is done now using r33 one
and in a few weeks it should be a goooer :headspin:
cya
Brad
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
