hey cheers for the comments :(
hey tiger im not sure exactly because i bought it already lowered, i found the springs are apexi and yellow but shockies r stock nissan ones, sorry cant give u more info :rofl:
ill measure it when i get the front struts back on and that wont be for a week or so :rofl:
cya
hey happymeal yep i take all the photos myself :rofl:
latest update on the stag 26 conversion:
we have cut a 4" hole in the firewall to recess the clutch master vacuum booster into the cabin abit to clear the engine :)
pedal box is mounted and lines up perfecto with the other pedals :(
got the front struts off atm, and repainting all the underside of the gaurds, and struts/suspension stuff to clean it all up. getting the bonnet latch, radiator mounts and a few other bits and pieces chromed while they are off too cause they look like shit atm.
took a photo of the suspension springs and shocks, ones cleaned and ones how it looked when they came off the car :D
26 will be test fitted next weekend to check clutch master clearance and try out my new baffled enlarged gtr sump i just got :aroused:
gotta move the power steering resoviour to the front so i can fit two 3" intake pipes on the inlet side :D just needs two longer hoses (thankfully it aint the metal lines i gotta change)
gotta make the front pipes from dumps/cat convertor after that and then sort out the handbrake using a r33 one probably, then the tricky wiring and stuff is gonna be sorted by hyperdrive motorsport thankfully :D
so around end of january and it should be goin if everything goes to plan :rofl:
cya
Brad
oooh baby cant wait till you take the beast down to the track for a run down the quarter she should reel off a fairly impressive time ;)
what other mods are planned?
hey mate well plans atm are
rb26 engine
gtr 5 speed
twin plate clutch
highflowed turbos (stock housings, bigger wheels)
sard 700cc injectors
twin 3" k&n pod filters
3" cooler piping
3" intake pipes to turbos
bosch motorsport 044 fuel pump, and better intank pump (not sure what yet)
gtr intercooler
autronics smc ecu :rant:
custom BOV
oil catch can
external oil filter kit
enlarged and baffled sump
in the vl it made 350rwhp only revvin to 7200rpm, and can rev to 8500rpm but i told him to be easy incase something is worn and i really wanted to use it abit b4 i blew it up :rant:
thats the stuff i have atm from the vl so next upgrades are...
apexi or similiar 100mm+ cooler
hks 2530 turbos
with those 2 mods alone my tuner reckons power will go from 350rwhp with highflows to 450rwhp with 2530s and cooler, boost :(
and the 2530s will be more responsive than the highflow turbos as mine are slightly laggier than stock gtr ones and hks 30s r the same as stockies :headspin:
so in the vl it did 12.0 @ 118mph (low 11s roughly) thats on slicks too.
with 4wd it should be a 12 second car for sure :) and with the 2530s maybe 11s on street tyres is possible :)
sure will shock the local hsv/xr6T guys :rofl:
a volvo shaped wagon eating there 80K hsv :aroused:
thats enough from me
cya
Brad
dont forget i want a ride brad :(
gary mate you will hear from me when its goin and ill take u for a spin :headspin:
also tomorrow im test fitting the rb26 engine in for the first time :( to check clutch booster clears the plenum and then we gotta make new exhuast from the 3" dump pipes (already made from VL install) to the single 3" cat back system on the stagea at the moment, so we will run twin 3" upto a merging pipe and into a single high flow cat or one of those really $$$ ones they tested in a recent zoom or HPI magazine that flowed heaps better than normal high flow units.
piccies to come and info as it happens
:P
Brad
Looking good so far.... Also looking forward to seeing you out and about on the streets in the future....you need to bring it to a SAUWA event in future so I can check it out.... Always been interested in the Stagea's and their potential :D
  • 3 weeks later...
no worries gary :cheers:
and yes ill be cruisin in the future for sure :)
recently put 4wd sump onto engine and installing engine in bay for final time tomorow :) had to remake the front turbo dump pipe to clear the passenger side driveshaft on the sump.
as i said in other post the handbrake is done now using r33 one
and in a few weeks it should be a goooer :headspin:
cya
Brad
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
