hey evryone, despite my recent radiator setback :), i been saving up for a veilside kit. i love it so much, but i was wonderin will i get crap for veilsiding my pretty much stock 33 gts?
i will be putting performance mods in the future, but i wanted to do show before go, dont ask me why, i just wanna :P
all opinions appreciated :)
cheers
https://www.sau.com.au/forums/topic/58687-na-veilside/
Go for it? Although have u seen a vs kit on an r33 in real life before? They look alot different to the pictures
Yeah I rekon the whole Veilside kit for the R33 looks sweet except the front bar. Would prolly change it for a 400r or something similar, just my opinion though.
https://www.sau.com.au/forums/topic/58687-na-veilside/#findComment-1123535
it is your car who gives a rats ass what other people think this is what makes your car unique and makes it yours just as long as you like it thats what counts..
just like a couple of people i know one has a worked rb25det in a vs commodore
and the other has rb26det with big single high mount turbo in a torana its diffrent
https://www.sau.com.au/forums/topic/58687-na-veilside/#findComment-1123617
It's been a while since I've posted, but I'm in the same boat as you. I have a 300zx NA and I got a full (semi custom rear) veilside kit put on...why....coz NA imports are never going to make tremendous amounts of speed. So they may as look sweet and feel even better to ride in.
Some pics
https://www.sau.com.au/forums/topic/58687-na-veilside/#findComment-1123701
lol, DONT DO 400r!!! cuz i am, lol
and ive got the drift wing as well.
and twin tip exhaust, i'll put up pics once its done, should b abt 2 weeks.
then getttin it lowered and that'll b the end of it. i cant afford to spend anymore money on it and fund a gf at the same time. ohhh, and hopefulli one day i'll b able to afford 18's as well.
https://www.sau.com.au/forums/topic/58687-na-veilside/#findComment-1124549
yo AusZXxx, i saw ur 300 at cott a couple of weeks back, bro ur car is ***n sweet ;) just thought id let u kno :cheers:
cheers guys i will look into different front bars, and let u kno when im done :)
:uhh: AFTER i pay for the damage i did last night to my rim, tyre, and rear left suspension....so umm ill post u guys around 2006 :goddam:
https://www.sau.com.au/forums/topic/58687-na-veilside/#findComment-1128006
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
