Sunshine People '05 & Summadayze '05
  • Replies 115
a rave from spring 2004 in japan or something
the rave / trance scene here in japan is amazing..... theres always some big party every weekend in the mountains on the beaches the past 2 weeks ive seen john digweed, ferry corsten and carl cox.... but usually the smaller private raves are the best.
Rather than start a new thread I'll just say in here I went to Breakfest yesterday and it was fantastic!!
Afternoon sun was a lil warm but nothing terrible, then from dusk to the evening the weather was absolutely beautiful and there was a nice breeze blowing about (Sometimes a bit of a wind if you were up the very top). I dunno why I've heard so many negative things about Belvoir as a place to hold an event but yesterday was my first time there and it rocked :)
Bliss n Eso went NUTS! Running thru the crowds jumping about they put on an awesome show, then later at the Ambar afterparty they were stumblin around a bit plastered :P
The other acts were also good, and although I do still prefer the harder, heavier DnB to Breaks, I'm glad I got to go. I also scored a wicked 'break-a-holics anonymous' top so I'm extra-funkular now :)
They had an enormous tank where you could refill your water bottles, plenty of foods like fruit, fairyfloss, salads and hot stuff to buy, as well as the required water, soft drinks and alcohol. They also had a stand where you could buy those long ice lolly sticks but they were made with fresh fruits and juices! Verrrrry refreshing!
Admittedly, the stairs are a bit of a bitch but I think that's the only gripe I have with the place. The afterparty went off and I think was meant to finish at 3am, but I left at 3:15 and I don't know when it actually did end...
Anyway! Big up Belvoir, was a right royal show. w3rd.
-Lozzle
i ended up at breakfest after party even though i didn't go to breakfest, but it was still cranking when i rocked up at 2.30am....... didn't leave till about 5am and i think many others were there till even early hours :headspin:
was surprised at how crankin the afterparty acutally was :D
adrain :cheers:
yeah it's at Monkey Bar/Amplifier Bar
and Bad Company is headlining it so that is a definate :(, pendulum, dj deekline........ and others :(
caaaaan't wait...
apparently free entry only if u have a wristband from sunshine people......
adrian :P
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
