Hi all,
I am selling my HKS GT2530 turbo off my R33 GTSt, complete with EVERYTHING you need to bolt it up (possibly bar one fitting, which might need to be made for a water feed)
I purchased the turbo alone nearly a year ago, and then separately purchased brand new parts to complete the bolt-on kit. These include a Genuine HKS stainless split dump (not cheap!) and high quality braided lines. Also a 1.2bar actuator (with adjustable rod) which was purchased new.
When purchased the turbo was as new condition with less than 5000kms on it, and i have since done only 10,000kms with it. The only reason for sale is the arrival of my new HKS 2835 kit.
so you get: turbo, dump, lines, 90 degree compressor outlet elbow, braided lines and fittings, all metal gaskets, wastegate actuator. Basically everything you need.
How good is this turbo?
The maximum figure i achieved was 227rwkw, made at 1bar. You can run very high boost through the midrange if you want, but on a 2.5litre the boost will drop off just at the top of the rev range. My best track time was a 12.5 at 115mph, with a slow 2.1 60foot, so you can see the potential with a good launch.
On an RB20 higher peak power figures may be obtained due the lesser exhaust gas allowing more than 1bar to be sustained over 6-6500rpm.
The torque increase makes a stock turbo feel truly weak, this kit is an awesome responsive upgrade, and makes for a very quick street car.
Price is $2100 and this is strictly firm.
***Please post questions related to this turbo/kit only please. I dont want to have to explain differences between this and a highflow, or other HKS models, or garret equivalents etc etc! so if you want to know, there are plenty of threads so please have a search.
cheers! Allan
https://www.sau.com.au/forums/topic/58978-hks-gt2530-complete-bolt-on-kit/
hi dude, myself and the kit are in adelaide.
have had a fair bit of interest but each buyer is short of cash due to xmas! This is not a problem for me, the kit is here complete, who ever shows me the 2100 first its theirs.
i will send anywhere at buyers cost.
cheers guys.
the turbo is all cleaned up ready to go, shaft play is like brand new, gathered by comparing it to my brand new HKS unit. So many of these so called 'low km' turbos look crap and have dings and nicks in the compressor wheel inducer, this one is gorgeous, you will want to put it on the mantle piece, not in ur car :)
***SOLD***
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
