Hey guys,
Over here in NZ we're allowed the luxury of radar detectors (and believe me they are a luxury - even if you're not the type inclined to speed they do give a little extra piece of mind). I was told they are completely illegal in Aus, what's the penalty for being caught with one??
https://www.sau.com.au/forums/topic/58989-naughty-ol-radar-detectors/
My Road Angel is one of my best investments yet.
As I understand it, it's avoided being banned by the police because it's a "hazard/blackspot warning" device.
The logic- speed/red light cameras are *only* placed at accident blackspots (not places where they generate the most revenue right) so the Angel is just another road safety tool.
Aside from giving advance warning of accident blackspots (aka speed/red light camera sites) it also shows:
■ School safety zone warnings during school hours
■ Railway crossings
■ Country town entrances where speeds change (from 100 to 60 kays)
■ Point to point speed safety cameras
■ Multanova safety camera areas in Perth
? School safety zone warnings during school hours
? Railway crossings
? Country town entrances where speeds change (from 100 to 60 kays)
? Point to point speed safety cameras
? Multanova safety camera areas in Perth
how much do these road angels cost?
They are perfectly legal to use and own, been pulled over many a time with mine up.
They also pick up road works, crew signals and emergency vehicle signals.
They should be allowed in other states if u ask me as they are advising u of upcoming dangers.
Politicians lick nuts
PS if you buy one for $300 you are wasting your money i wouldnt spend under 800, that or buy a second hand top of the range one.
They are totally legal in WA. However, if they really want to ping you for something they will get you for obstruction of vision. I have been warned on this so now when i get pulled over I quickly remove it for peace of mind. Also, I feel it gives the cops and extra reason to try and get you for something else seeing as it gives them the notion that "this guy must speed alot and thats why hes got a radar detector etc etc.
Word of advice: try not to drop the detectors. Mine still works ( as in beeps etc) but i have lost the visual side of things.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
