  • Replies 154
I'm going on the 26th of february.
Can I just say to everyone here that it's a bit surprising that 30 odd people have emailed me and confirmed yet only about 6 have gone and got their windows tinted so far.
I know we have 3 months but I would have thought that was only necessary for about 5 of the 30 odd.
What's happening peoples?
Don't worry too much about days set aside, call him and book your time.
I'm just waiting to sort out my air con as i always drive with my windows down. :)
One of my old tints have scrathes on it due to something rubing against it when opening and closing. Can he fix that? I would hate if my new tint got scratched.
I'm just waiting to sort out my air con as i always drive with my windows down.  :rofl:
I'm in exactly the same position: need to sort aircon ASAP because 48 hours with the windows up and no aircon = hell.
LW.
I have a window regulator problem that I need fixed before I get the windows tinted, as apparently when replacing it, it is very easy to scratch the window tint.
Hi Guys,
Few weeks down the track and im totally happy with the tints.
Heres couple of photos of 28% tint
Im so glad i did it since sydney has still been pretty hot and sunny, plus the price was great considering solartint wanted $300 for all my windows!
Yeah I saw the white R33 there it was a looker :(
Maybe my tint isnt as dark or something, or the type I chose isnt as great, but mine is far less dark than yours was. Robert said you had 28%, but maybe you went the other 28% film he was offering.
Oh well, *shrugs*. You live, you learn.
Booked in for this Saturday morning: 7:15AM :spew: -- Robert is a "morning person".. he starts at 6:00AM! -- I, on the other hand, am not :D He has been extremely helpful so far, fitting me in at extremely late notice :)
locosam / MarkE: which films did you go with? I think Robert mentioned he has a Cybertint and a something else @ 28 percent. Just wondering which is which :)
cooky2511: picsorban :)
LW.
Mine was the 28% non reflective.
Reflective looked really good on his ute, but i didnt think the reflective would suit my car much (plus i didnt want the extra attention from police). Im not sure what he called it, but it was the same as roberts ute
Got my car done on Sunday morning (28%, non-reflective). Only had time for one quick piccy because it started raining:
Before (when car was in Japan):
After:
Let me also add to the praise for Robert: he is just a top bloke. Fitted me in last minute, nothing was too much trouble, extremely helpful. You couldn't ask for me. Do the right think by him guys: if you put your name down, give him a call an organise a time to do your tint.
Thanks also to Adam for organising the group buy.
Lucien.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
