Intercooler & Intercooler Kits?? Questions??
Guest RedLineGTR
Hey, I’m after people’s feedback on what intercoolers (FMIC) they have installed on their cars specifically on the Nissan Skyline R33 GTS-T and what modifications they had to do to install them. Such as:
- Cut The Front Bar?
- Cut a hole for the return pipe on the side of the engine bay?
- Did You Have to cut the fan blades for the return pipe when it goes over the engine?
- Was the R33 GTS-T Series 1 Or Series 2?
- If it was a Series 1 R33 What front bar did it have on it? (Type S or M)
These are the kits i have been looking at...with some of these kits a have some specific questions for people who have installed them, any other brands please feel free to suggest them as well :P
Hybrid (Genuine)
- Did you have to cut the fan blades to fit the return pipe?
- Did all the pipes line up correctly?
Trust / Greddy
- Which kit was purchased?
- Did you get the cooler with the return piping or the one that goes over the engine?
Blitz
- What front bar did you install the kit on??
- Was it the LM model intercooler kit?? if so did it all line up?
- Did the return pipe from the blitz lm kit stick out from the bottom of the bar??
Custom (Melbourne People)
- What size and piping options where available?
- What type of intercooler core was used??
- Where was the work done?? Where you happy with the job?
I have looked at a lot of threads and info on the forums about intercooler kits etc, i have seen a lot of people install specific kits that they were happy with but never had any little write-ups on the kit or intercooler they had.
Hopefully this thread will help me with my choice and aid others when they are ready to get one in the future.
Cheers Rob
P.S i have heard mixed stores with specific brand kits with cutting fan blades and other items that people have different opinions on which if i install it myself i want to know 100% what needs cutting etc.
I jus fitted a Hybrid FMIC on my R33, had to cut hole in right guard for pipe, cut fan blades to fit the pipe over the engine, swapped reinforcement bars with a mate who had it already cut out for the cooler and GTR front bar, took most of the day, but looks sweet and all pipes lined up perfectly
Yes had to cut front bar and remove the innards
had to, just below water tank. no problems
not required as return pipe cleared fan ok
series 2
2.5" pipes, supplied by workshop. stainless steel
no idea. just a hybrid model one it looks like. its an intercooler, it cools
the core isnt the normal 600x300 size its a bit smaller
ive only lost a tiny of of low end after fitting it
only mods are pod filter
chasers in kensington. very good work. 6 hours work.
good price. price included, all fitting, pipes, core and labour
Trust / Greddy
Trust V-SPL intercooler kit, comes with detailed instructions and all necessary clamps and fittings 600*300*65 I think, or was it 75
easy enough to install yourself if you dont mind drilling a hole in the engine bay
The kit requires you to drill a hole on the driver side engine bay for the return pipe and the pipe goes over the radiator fan.
You dont have to cut the fan blades but there is small section of a thermo fan bracket located in front of the radiator that needs to be trimmed off so that it does not rub againts the back of the intercooler as well as a small section of the bumper support but thats no biggy with some elbow grease a big hacksaw
I was told the kit is the same for series 1 and 2
The instructions that came with it was for a series 1
My car is a series 2 and I had to trim the front bar quite a bit, but it fits nice and tight
I have a Blitz Lm intercooler kit which i just installed on my Series 2 R33.
The piping lined up perfectly, and i mean perfectly, not like some of the hybrid kit i've encountered. The return pipe inder the cooler stick out from the front bar by about 20mm or so, but i have a stock series 2 front bar and if u get an a/m one the pipe shouldnt hang below it. I had to cut a but off the back of the front bar and the support bar, but nothin a bit of angle grinding cant handle.
This cooler is one of the best coolers u can get for street use(not drag applications), the pipe from the cooler to intake manifold is sooo cold, even when driven hard. My previous trust vspl was not as effective in cooling the air as this one, and my mate's hybrid..well let's just say for the price it's alright, but u get what u pay for.
bought a used hks front mount kit
return pipe needed hole cutting below water bottle, no probs, just lined the metal on the bodywork with some fuel pipe that i split and pushed onto the metal, this is so that the return pipe does not bang on the metal work at all, had some slight knocking issues to begin with.
no fan blades needed cutting, seemed to clear ok, but the return pipe is just touching the radiator feed pipe, i'm sure this is not very good, and is bleeding heat into the return pipe... will need to sort at some point
yet lots of cutting of the front bar to do, although i used a hand grinder ( 4" ) with a thin metal wheel, and it makes cutting the bar REALLY easy, its also easy to make decent radius cuts as well ...
i made up a couple of metal brackets to support the fmic, just used holes in the box chassis, then bolts into the side bracket points on the fmic, if the mount lugs are on the bottom of the ic, then a simple mode to extent this to under it would be easy ...
i did all this in a full days worth of work, the largest portion of time was cutting out the front bar, and making it look reasonably good ... other than that, only really basic garage tools are needed, and a grinder (one of the most all round useful tools i ever purchased) grinders are also pretty cheap ... $80 or so gets you a reasonable bosh one from bunnings !
let me know if you have any questions, i can email some pics if needed
cheers
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
