Hey all,
well last night i was at the drags and on me way home i realised my clutch seemed to feel very soft and that changing into some gears seemed to be taking a while to engage, (ie. wouldnt just grab and go)
anyways..
i basically think ive f00ked the clutch or its on its way out... and am wondering how much roughly it would cost me to get a clutch thats good for 250-300hp..
(dont want full blown heavy duty as i wont need it... due to lack of turbs :) :) but i want something that is tough as nails and wont give out)
any suggestions and prices please people ?
https://www.sau.com.au/forums/topic/59418-new-clutch/
definatley recomend auto clutch. That guy has prolli worked on every performance 'line, 180, silvia and what not else in this state. When i went down he was booked solid for two weeks with nuttin but sports cars. very reasonably priced too. expect to pay 5-600 for a heavy duty clutch. thing is, he rebuilds ur old clutch but its better then new!!!!
https://www.sau.com.au/forums/topic/59418-new-clutch/#findComment-1134292
Exedy heavy duty clutch kit to suit rb20, from hi tech in osbourne park, it comes complete with clutch plate and new pressure plate, i cant remember if rb25de is the same fly wheel as rb20 though.
www.adelaideclutch.com.au
Will ship you a kit at a decent price ive found.
https://www.sau.com.au/forums/topic/59418-new-clutch/#findComment-1134404
i had this problem trying to find wat size clutch disc i needed. from memory, some rb25de have the same size wheel as a rb20 -9inchs i think. But tthen there are some other ones which seem to have a 10inch wheel. mine had a 10 inch wheel. So u just need to pull the sucker out first and find out or hope for the best. Just abt any place will allow you to return the clutch if its the wrong size. just so long as its still in brand new condition **obviously**.
https://www.sau.com.au/forums/topic/59418-new-clutch/#findComment-1134498
"yeah 2500lb pressure plate is quiet heavy but you do get used to it and it grabs very sharp and well"
I agree with C yar on this, I had a 2500lb, 9 puck clutch fitted by Xspeed in Myaree, cost $850 but so pleased with it,not that hard to get used too and at least you KNOW it won't give you trouble for some time :)
https://www.sau.com.au/forums/topic/59418-new-clutch/#findComment-1134958
I agree with C yar on this, I had a 2500lb, 9 puck clutch fitted by Xspeed in Myaree, cost $850 but so pleased with it,not that hard to get used too and at least you KNOW it won't give you trouble for some time :D
:werd:
I went for the 9puck Ceramic w/2500lb pressure plate :) You do get used to it, but YES it is a bitch to drive in traffic. Thank god I don't do much peak driving anymore!
Paid close to $1k for it :D
https://www.sau.com.au/forums/topic/59418-new-clutch/#findComment-1135185
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
