Hey all,
well last night i was at the drags and on me way home i realised my clutch seemed to feel very soft and that changing into some gears seemed to be taking a while to engage, (ie. wouldnt just grab and go)
anyways..
i basically think ive f00ked the clutch or its on its way out... and am wondering how much roughly it would cost me to get a clutch thats good for 250-300hp..
(dont want full blown heavy duty as i wont need it... due to lack of turbs :) :) but i want something that is tough as nails and wont give out)
any suggestions and prices please people ?
https://www.sau.com.au/forums/topic/59418-new-clutch/
definatley recomend auto clutch. That guy has prolli worked on every performance 'line, 180, silvia and what not else in this state. When i went down he was booked solid for two weeks with nuttin but sports cars. very reasonably priced too. expect to pay 5-600 for a heavy duty clutch. thing is, he rebuilds ur old clutch but its better then new!!!!
https://www.sau.com.au/forums/topic/59418-new-clutch/#findComment-1134292
Exedy heavy duty clutch kit to suit rb20, from hi tech in osbourne park, it comes complete with clutch plate and new pressure plate, i cant remember if rb25de is the same fly wheel as rb20 though.
www.adelaideclutch.com.au
Will ship you a kit at a decent price ive found.
https://www.sau.com.au/forums/topic/59418-new-clutch/#findComment-1134404
i had this problem trying to find wat size clutch disc i needed. from memory, some rb25de have the same size wheel as a rb20 -9inchs i think. But tthen there are some other ones which seem to have a 10inch wheel. mine had a 10 inch wheel. So u just need to pull the sucker out first and find out or hope for the best. Just abt any place will allow you to return the clutch if its the wrong size. just so long as its still in brand new condition **obviously**.
https://www.sau.com.au/forums/topic/59418-new-clutch/#findComment-1134498
"yeah 2500lb pressure plate is quiet heavy but you do get used to it and it grabs very sharp and well"
I agree with C yar on this, I had a 2500lb, 9 puck clutch fitted by Xspeed in Myaree, cost $850 but so pleased with it,not that hard to get used too and at least you KNOW it won't give you trouble for some time :)
https://www.sau.com.au/forums/topic/59418-new-clutch/#findComment-1134958
I agree with C yar on this, I had a 2500lb, 9 puck clutch fitted by Xspeed in Myaree, cost $850 but so pleased with it,not that hard to get used too and at least you KNOW it won't give you trouble for some time :D
:werd:
I went for the 9puck Ceramic w/2500lb pressure plate :) You do get used to it, but YES it is a bitch to drive in traffic. Thank god I don't do much peak driving anymore!
Paid close to $1k for it :D
https://www.sau.com.au/forums/topic/59418-new-clutch/#findComment-1135185
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
