254 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Gotta say I am a 32 fan all day way GTS-T or GTR so yup 32 is def my fave, next to that would be the 34 then 33.. I really hate choosing but seriously NO SKYLINE IS UGLY!!!! I cant believe you'd even think it :) every skyline has potential (fave 33 for instance krzysiu :))
  • Replies 75
ohh i have a bit of a retro (or 'old school') fetish. dr30/r31 passage. mm. for that matter, i like pretty much all dark, low 4-doors. (dr30 aside, as it looks best in its original two tone paint and rs-x turbo printed on the rear doors :drool:)
out of the three being poled? r34, cause there rarer and no one can afford them :)
  • 4 weeks later...
    • There are black hose clamps as well if you care. Plazmaman for example sells some: https://plazmaman.com/product/black-hose-clamps-premium-quality-stainless-breeze/
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
