Ok im not saying that this car doesnt look nice....it just looks so much more different then what i expected.... even though i've only seen the proto-type. im sure its power makes up for the looks, i mean how many street cars that have a V8 with TT in them do you see everyday...
https://www.sau.com.au/forums/topic/59460-the-r35/
i thought it would of been best if they kept the tradition going, why would they change the R?
how depressing....
oh well i dunno how to change the topic name so ill leave it as it is.... anything else i should know about the "V35"??
https://www.sau.com.au/forums/topic/59460-the-r35/#findComment-1134218
The V35 looks nothing like the “R” series of Skyline; instead it looks like a recipe for a 350z gone wrong. The V35 did not carry on the RB26DETT either, instead now powered by a V6 VQ35DE producing 298Hp @ 6,400rpm/260lb-ft torque @ 4,800rpm on the manual model and 280Hp @ 6,200rpm/270lb-ft torque @ 4,800rpm on the automatic all delivered onto a Rear Wheel Drive system. The V35 has also replaced the Circle-Shaped Rear Lights with an ‘L’ looking shape. Available as a Coupe or Sedan. This is were it gets hectic, there are a lot of V35 models; 250GTe, 250GT, 250GT P 250GT S, 250GT FOUR, 250GT FOUR P, 250GT FOUR S and 250GTm all came with a VQ25DD Engine. The 300GT, 300GT P and 300GT S all came with a VQ30DD. And lastly the 350GT-8 came with the VQ35DE.
There is also a V36, set for 2006 I think, cant remember. Anyways just read through The Next Skyline Section and you will get everything you need to know on the V35 and Next GTR
https://www.sau.com.au/forums/topic/59460-the-r35/#findComment-1134242
how depressing....
What tradition? This is what I don't get... Nissan release only 5 (!!11) platforms bearing the 'R' designation, yet people seem to think that GT-R = RB26 or R is synonimous with Skylines whatever...
I ask: What about the C10 and C110 GT-R's????
Are they not GT-Rs in the true sense, being that they were released BEFORE the R32/33/34?
If you wanna talk about GT-R tradition, tradition starts with a capitial C.
If you wanna talk about Skyline tradition, tradition starts with a capital A,B,S,C and R...
Cheers :rofl:
https://www.sau.com.au/forums/topic/59460-the-r35/#findComment-1134349
Rezz not arguing your point but I think for a lot of people the R series is the defining series of the skyline.
I'm 22 and certainly in my lifetime the skyline is symobolised by the R.
But your point is taken.. damn these love those C's in Japan dontthey!?
https://www.sau.com.au/forums/topic/59460-the-r35/#findComment-1135188
the R symbolises invincibility and i think that all skylines in the current series should have one. otherwise doesnt it kind of seem like the "V35" is being left out of the crowd?
kinda like me around here =P
but its not the same series at all. different engine different chassis(???spelling???) and different body. there is hardly anything that is the same except the name.
https://www.sau.com.au/forums/topic/59460-the-r35/#findComment-1135639
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
