  • Replies 416
Posted Images
well here are their specs:
Windows® System 98/ME/2000/XP OS:
* 800 MHz or higher CPU
* 256 MB or more of RAM
* 32 MB 3D graphics card with hardware transform and lighting, such as GeForce 2 or better
* 4 GB or more of available hard drive space
* DirectX® 9.0c or above
* A 56k or higher modem with an Internet connection
im running a 1.4 with a radeon xtsomethingi card thats pretty good and 512 ram, should be fine :D
its a wicked game by all accounts.
im a WC3 junkie  lol... and WoW looks even better... once i get my free broadband in about 3-4months no doubt ill jump on
you can play it with dailup.. i only had dail up for the 1st couple of weeks of playing.. its not that bad
    • So I'm going to have to keep ignoring the 4.7 update, or whatever version it is? Poop. I was hoping you'd put me out of my misery.
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
